Author Topic: Xenon HIGH/Main Beam Bulbs HB12 FIAT 126 - 60/55 watt  (Read 3026 times)
« on: April 02, 2010, 12:11:25 PM »
I am wondering whether using a higher watt headlight bulb of 60/55 watt will work. I think we ascertained previously that proper xenon lightbulbs will only do harm than good. The manufacturer's recommended headlight bulb is 40/45 Watt bulb. There is a xenon effect headlight bulb being sold on ebay.
http://cgi.ebay.co.uk/Xenon-HIGH-Main-Beam-Bulbs-HB12-FIAT-126_W0QQitemZ280395699333QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item4148e2d485
« Last Edit: April 02, 2010, 12:25:01 PM by Amateb8 »
jose
Re: Xenon HIGH/Main Beam Bulbs HB12 FIAT 126 - 60/55 watt
« Reply #1 on: April 02, 2010, 01:31:15 PM »
I'm interested in these... What was the conclusion that they will do harm about? I understood it that you could fit the bulbs but they wouldn't make much difference unless used with one of those power enhancer units you can get with some of the bulbs, a little more expensive though and i might be wrong... Would like to find out how to brighten my lights though
126BIS 1990
« Reply #2 on: April 02, 2010, 01:46:13 PM »
Do not think about fitting high power bulbs unless you also fit a relay to switch the power otherwise you just melt your column light switch  [-/
« Reply #3 on: April 06, 2010, 09:01:31 AM »
I think the BIS had a relay system Rusty, well the one (F reg) like I had, but youre right, i know coz I've done it :oops:
« Reply #4 on: May 02, 2010, 06:29:23 PM »
I think the 126 Bis has a relay already fitted as mentioned by Darrell. I replaced the clips that held the headlights in place and thought of replacing my headlight bulbs to yellow ones (please see refer to my other thread entitled, "yellow headights") and found that both headlights had H4 60/55 watt bulbs (halogen but non-Xenon?).
« Last Edit: May 02, 2010, 07:10:50 PM by Amateb8 »
Jota69
« Reply #5 on: May 02, 2010, 10:46:33 PM »
I fitted some hid lights on mine, they are super bright
RSPSTEVE
« Reply #6 on: May 03, 2010, 08:31:01 AM »
As i use my 126 as my daily , i will get these fitted before the winter .
jose
« Reply #7 on: May 03, 2010, 01:26:50 PM »
jota was this a straight forward conversion?
126BIS 1990
Jota69
« Reply #8 on: May 03, 2010, 05:30:35 PM »
yes it's pretty straight forward, you will need modify the headlights so the bulbs will hold on the stock location and find a place for the ballast, I also fitted some relays so the stock wiring would not get damaged due to the higher wattage of the new bulbs.
