Author Topic: Wiring the fan to a manual switch? frightened of it over heating!  (Read 1988 times)
andyj_corfu
  • BIG RED
Hi im a new owner of a 126 Bis and in the middle of refurbishing the beast and have a few welding jobs that i need someone to do and the cylinder head to put back on (NICE) but i have heard stories of a problem with the engines over heating.
Is there anyway of identifying if the the water pump is working.
Ive never seen the cooling fan working but saying that ive only run the engine for about 5-10 mins max so the engine probably isnt getting hot enough to kick the fan in.
Ive heard that having a manual switch would be a good idea.
Does any one know the best way of wiring the fan to a switch and which power source to tap off from?
Any help would be great
jose
Re: Wiring the fan to a manual switch? frightened of it over heating!
« Reply #1 on: March 27, 2010, 08:01:05 PM »
somewhere (maybe on here) I read about a variable thermo-switch which you can manually set so the fan kicks in at a lower temperature!   I guess you would just connect it into the live feed to the fan and an earth, and there is a temp sensor on a wire you must feed into one of the water pipes, someone correct me if i'm wrong!
126BIS 1990
« Reply #3 on: March 28, 2010, 08:34:58 AM »
What year is your Bis?
hudsonhenry
    • http://www.retro500.com
« Reply #4 on: March 30, 2010, 09:13:00 AM »
Make sure that your manual switch is an override to the automatic system, if not then the day will come when you forget to turn the fa on and don't spot it until too late  [-/
andyj_corfu
  • BIG RED
« Reply #5 on: April 07, 2010, 08:28:07 AM »
my car is an 1989. cheers for the help so far guy most helpful
