Author Topic: Wheels wheels wheels...  (Read 3404 times)
jose
« on: March 26, 2010, 06:59:40 PM »
Hi Guys,
does anyone have any thoughts on hub adapters to convert Fiat stud pattern to 4x100 pcd, I may be having some made and just wondered if anyone might be interested as I know I've found it hard to find some wheels! I ended up painting my steels which look sweet but they're very narrow!
This will match the stud pattern to that of older volkswagens, audis, vauxhalls, and some renault, nissan etc obviously creating a much larger after-market wheel selection! thanks, feedback much appreciated
126BIS 1990
Re: Wheels wheels wheels...
« Reply #1 on: March 26, 2010, 07:57:35 PM »
Back in the good old bad old days I ran some big 100 pcd Wolfrace rims on a 126 but they had press in inserts which I replaced with offset inserts I made. Now the talk is about wobble bolts but which I have reservations about. There are 98 pcd rims out there & you have just gotta track them down , Fiat Alfa or Lancia. Also ran a set of Uno turbo alloys  [-/
« Reply #2 on: March 26, 2010, 08:10:52 PM »
As rusty says there is an aray of wheels out there here's a link that maybe of use ;D
http://www.carlsalter.com/wheel_fitments.html
jose
« Reply #3 on: March 26, 2010, 09:01:30 PM »
yeah those wobble bolts aint the best way of solving the problem!  :-
Sure there are some 4x98 available i've spent hours sifting through wheels, there's just a much wider selection of 4x100s though... personally i really like some of the old steelies too, they all have a bit of dish on em.  like these beauties, shame there's only 3...
http://cgi.ebay.com/ebaymotors/Fiat-Abarth-Wheels-4x98-12-x6_W0QQcmdZViewItemQQhashZitem25598c6677QQitemZ160416163447QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
126BIS 1990
« Reply #4 on: March 26, 2010, 09:51:43 PM »
wobble bolts will take up 2mm you might need to buy some spigot rings but you can get those from ebay made to order...
jose
« Reply #5 on: March 26, 2010, 11:59:54 PM »
not feeling the wobble bolts though tbh! dont like to cut corners really!
126BIS 1990
gsxr126
« Reply #6 on: March 27, 2010, 12:57:51 AM »
Offset inserts are the way to go. A mate has just done this mod to his 17inch 4 x 100 wheels. Theyre going on an 850 coupe. With a 126 i would be replacing the wheel bolts with studs if any kind of aftermarket wheel is used. I have seen too many fiats (mostly 850s and 124s) lose wheel bolts usually with disasterous results. Thankfully none of these have been 500s or 126s but thats probably related to the power output...
Then again ive seen fiats with 100PCD wheels fitted straight on the hubs and havent ever had any probs
Oh yeah, just wanted to mention that the diff in PCDs is 1MM not 2
jose
« Reply #7 on: March 27, 2010, 02:37:57 AM »
what are offset inserts?
126BIS 1990
gsxr126
« Reply #8 on: March 27, 2010, 04:11:39 AM »
They are press fitted 'washers' that are located in the wheel bolt hole. Usually made from a harder alloy and splined on the inner face. Not all wheels have inserts so you'll need to find a set of wheels that has them.
I suppose you could machine a set of alloys to accept press fit inserts.
It works well. A mate has done this to a few sets of wheels and hasnt had any probs. He has a (wait for it) 300+bhp  lancia headed, supercharged, turbocharged 2litre fiat motor in an 850 coupe
« Reply #9 on: March 27, 2010, 07:48:07 AM »
fair point.
« Last Edit: March 27, 2010, 07:54:05 AM by stuey »
jose
« Reply #10 on: March 27, 2010, 09:07:26 AM »
interesting!  i think these hub adapters are good also because they serve a second purpose as a spacer which you may need anyway for certain wheels.
126BIS 1990
gsxr126
« Reply #11 on: March 30, 2010, 04:47:36 AM »
Hub adaptors should only fill the space between the OD of the hub and the ID of the wheel. If used as a spacer there will be too much tension on the bolts when tightened.
jose
« Reply #12 on: March 30, 2010, 06:24:45 PM »
if they bolt directly onto the hub, and the wheel bolts straight on to the adapter they naturally space the wheel, that is what i'm saying
126BIS 1990
