Author Topic: wireing ??  (Read 2624 times)
bobblehead
  • monkeys on the move ..
    • my fiAT 126 PICK UP
wireing ??
« on: March 26, 2010, 06:45:56 AM »
hi there, i have secured a fuel pump for one of my bis cars as a run, see if it fixes trouble im having,  manufacturer said i could take a feed off the coil ??
which feed from the coil ? or how could i find a alternative feed please?
i think its earthed at the body, then just has a power and , once plumbed in hey presto he he ..
my concern is, if its a permenant live, wont it run when the car is off, flood the carb and kill the battery ? or dont pumps do this?? ..  im confused ??
ive seen it wired to a wire off a back light before i think ? how does that work ?
any help would be greateful .... he he
the manufactuer said to wire it to the coil, howver it  might mess with the rev counter of the car... he he i told him  these cars dont have rev counters he he :P
Re: wireing ??
« Reply #1 on: March 26, 2010, 07:33:44 AM »
one side of the coil is a switched live from the igntion switch (ya key) put a test light on either side of your coil and switch your ignition on and see which one lights it up and use that- the pump should have an auto cut out on it so one its up to pressure it will just cut out...
bobblehead
Re: wireing ??
« Reply #2 on: March 26, 2010, 08:52:36 AM »
THANKS BUd
keep ya posted :)
Re: wireing ??
« Reply #3 on: March 26, 2010, 10:12:43 AM »
It may be worth checking the voltage at the + of the coil, just in case you you have a coil ballast circuit. I would personally source another aux feed.
Re: wireing ??
« Reply #4 on: March 26, 2010, 10:35:08 AM »
there are many ways to do it, you could put a switched wire in which can act as a nice theft deterrent.
bobblehead
Re: wireing ??
« Reply #5 on: March 26, 2010, 01:39:12 PM »
cant check any type of voltage, as dont have the knowledge or equipment ..
please a idiots guide for me would help
dont want anymore trouble , problems and money being spent :(
Re: wireing ??
« Reply #6 on: March 26, 2010, 02:17:29 PM »
headlamp bulb 2 pieces of wire.... ;D  no cash required for that...it will show you which one is the switched side without having to resort to expensive multimeters..
« Last Edit: March 26, 2010, 05:33:30 PM by stuey »
bobblehead
Re: wireing ??
« Reply #7 on: March 27, 2010, 03:42:07 PM »
problems ? :(
the new electric pump , works on a battery touching plus and minus, pumps fuel through nice
when i attach the pump to a earth and a positive on the coil, the pump is making a much quieter noise but isnt pumping ?
do i need another plus + feed??? a better earth ??
im all of a loss
help pleaseeeeeeeeeeeeeeeeeeeeee
p.s dont know if this matters either or not, pump old pump still in siture, with push rod in etc .. all ive done is take the in feed from the tank and put it to the pump ...
« Last Edit: March 27, 2010, 04:10:44 PM by bobblehead »
Re: wireing ??
« Reply #8 on: March 27, 2010, 08:52:59 PM »
just an idea..
Is this for the pickup bis 126? If so did you originally have a heated rear screen fitted? If so you may be able to adapt that circuit for an electric fuel pump.
bobblehead
Re: wireing ??
« Reply #9 on: March 27, 2010, 08:55:11 PM »
it is, and yes it did , i will find the connector block and see what i have to play with .
do i need to blank off old pump in order to make this electronic run proper?????
thanks for your info
Re: wireing ??
« Reply #10 on: March 27, 2010, 09:16:56 PM »
Blanking the old mechanical pump should make no difference.
Back to the wiring..
I would use an in line fuse fitting on the feed cable from the heated screen + connection. something like this http://cgi.ebay.co.uk/10A-Inline-Standard-Blade-Type-Fuse-Holder_W0QQitemZ300356951272QQcmdZViewItemQQptZUK_Cars_Parts_Vehicles_Terminals_Cabling_ET?hash=item45eeab5ce8
For the earth feed - I would run a new lead (black preferably) from the earth connection on the pump to a secure earth point on the body.
Use soldered connections on all connections!
Dont forget to leave the heated screen switch on when using the car. In fact it may be a good anti -theft device ;)
« Last Edit: March 27, 2010, 09:35:18 PM by ChrisRLewis »
bobblehead
FINISHED AND INSTALLED . THANKS
« Reply #11 on: March 28, 2010, 09:05:07 PM »
hi there, just to let you know today i wired up the fuel pump using the heated rear window switch as suggested , so not only does it work but i also have a anti theft measure he he :)
i cant believe i managed it, and thanks for everyones help and advice .
i feel i have to mention the guys at webcon for supplying me with a ultra quiet and efficiant (once knew what i was doing easy to install fuel pump with filter) .
thanks for the link to webcon supplied by DC .. HE SAID  " I've all the same problems as you except mine wont even start now  im going though everything thats been said on here and also considering an electric pump and found this http://www.webcon.co.uk/Downloads/2009-Jan%20WFP502.pdf  "
A VERY GOOD AND FAIR PRICE WAS PAID, and i promised them if i was sucessfull i would tell you lot about them .. so i have .
thanks again
richard :)  pleased as punch
