Author Topic: 125p/polonez ignition module on 126:help wanted  (Read 2451 times)
ape20ff
« on: March 22, 2010, 09:12:56 PM »
Hello. I don't know if I'm wrong writing here. In case of mistake you can delete my topic.
I've alredy write on fsoclub but it isn't visited often.
 Does somebody know if it's possible to use the  ignition module from polonez or 125p(I don't know from which ones) to improve standard ignition on 126?
If I'm not wrong I heard about this tip. Can somebody explain how to do this?
Wiring diagram, points set up, the right coil, in case of dry coil like 126 bis Does it take the resistive cable too?
Thanks in advance.
Bye
Re: 125p/polonez ignition module on 126:help wanted
« Reply #1 on: March 26, 2010, 08:30:49 PM »
I would think it is not possible because they are 4 cylinder engines. the polski FIAT CINQUECENTO used the 704cc 2 cylinder Bis engine and that had electronic ignition. or you could use the 123 electronic ignition module.
ape20ff
« Reply #2 on: March 30, 2010, 05:00:49 PM »
Hello to everybody.
Thanks for answering. I don't still know ho to do. I keep on searching.
The ignition module doesn't care the number of cilynders at all. In fact the ignition module used on piaggio poker(4 stroke, 1 cilynder only) is the same used on  4 cylinders cars.
I must use  the ignition on  a standard car to use daily. 123 ignition isn't cheap at all,it costs more much than the car. It has got no vacuum advance. I alredy know cc 704 ignition. I replaced it on cc with this:
http://ape.com.pl/index.php?id=44&produkt=164
I used it on tuned 126 too.
My project is the following one:
http://img483.imageshack.us/img483/6484/image001yn7.jpg
http://img406.imageshack.us/img406/2536/image002dm1.jpg
http://img248.imageshack.us/img248/7526/image004ti6.jpg
I found it on web. I think it's a good idea this sort of hybrid (126/126bis) distributor.
If you check the centrifugal advance you'll see that they have the same one.
Look at this:
http://fiat126.hu/image/h/1600/12059.jpg
As I discover what is the right module and how to use I'll report.
Thanks a lot.
Good bye
« Reply #3 on: March 30, 2010, 06:32:14 PM »
What are you expecting the difference to be by using 125P ignition module?
According to the Ape site the  20FF is for use on the EL model, this already has electronic ignition. Why not just use the system on an EL?
