Author Topic: seal carb ???  (Read 1945 times)
bobblehead
  • monkeys on the move ..
    • my fiAT 126 PICK UP
seal carb ???
« on: March 19, 2010, 09:20:25 AM »
hi there, i may have a leaky gasket on my carb?? how can i seal it ?? gasket sealer??? any help please??
also please look at my post bogging down as i have uploaded videos of problems now ??
cant anyone help ??????
thanks
richard
Alex
Re: seal carb ???
« Reply #1 on: March 19, 2010, 09:44:54 AM »
is it the gasket thats sandwiches in between the carb?
if it is, then the best bet would be to take the carb apart, carefully peel off the gasket, buy some gasket paper and cut out a new one, i had to do this for my carb.
Re: seal carb ???
« Reply #2 on: March 19, 2010, 09:46:23 AM »
Not sure what you can use but I made some enquiries about the rubber gasket at the top of the Bis carb and it turns out it is not availiable!  However, you could try WEBCON as they have a few parts for that carb.
http://www.webcon.co.uk/
fly
Re: seal carb ???
« Reply #3 on: March 19, 2010, 10:01:01 AM »
There's a carb service kit available on eBay, that might have the requisite gasket included?
Alex
Re: seal carb ???
« Reply #4 on: March 19, 2010, 10:16:09 AM »
in regards to the service kit, if your carb is not a weber, that service kit is about as useful as a chocolate teapot!!!
 ;D ;D
Re: seal carb ???
« Reply #5 on: March 19, 2010, 11:59:23 AM »
Dont use gasket sealer for assembling carburettors it can cause a lot of problems like blocking jets up. May be worth checking your float or the float height setting?
bobblehead
Re: seal carb ???
« Reply #6 on: March 19, 2010, 05:46:04 PM »
right... missed last post ... dam ... as ive subsequently just used a small amount of gasket sealer on the carb .. and touch wood  its done the trick ? :)
will let it go off and let you lot know tomorrow.
thanks for all your help and advice ... i have lost a very very small circlip from off the carb is anyone has one please??
 oh another question , the carb has a rubber on the top of it. then the black filter breather box thing ontop ...  a question , is the rubber meant to be attached to the black breather box around its rim ?? or just slotted on the carb . then sandwisched together when you do up the 10mm stud ??
and if i did the later , would this have caused me my problems?? ie maybe letting too much air in ??????
