Author Topic: bogging down ??  (Read 1867 times)
bobblehead
  • monkeys on the move ..
    • my fiAT 126 PICK UP
bogging down ??
« on: March 17, 2010, 09:55:47 AM »
situation im facing :
got a bis, i need to take for mot , it wont drive unless choke is on full .. minute i take choke off it bogs down, coughs and misfires .. bang bang bang and loses power / stuggles .
ive cleaned tank , replaced all fuel lines and filter . replaced fuel pump ...
anymore suggestions please?
as soon as its runing sweet i can drive to mot
please help thanks  richard
Re: bogging down ??
« Reply #1 on: March 17, 2010, 12:30:57 PM »
Could it be running too rich perhaps? fiddle with the idle mixture screw a little, turn it clockwise a turn or so
Alex
Re: bogging down ??
« Reply #2 on: March 17, 2010, 04:19:21 PM »
Hi Richard
i had the same problem with my carb! i replaced the old polish one with a Weber completely overhauled it, new jets, new float, new everything, and have tried in vain to sort it out myself but to no avail, i've had to get the garage to sort it now as i'm not sure what else i can do.
not much help i know but just understand your frustrations.
bobblehead
Re: bogging down ??
« Reply #3 on: March 17, 2010, 06:15:20 PM »
i have taken top off carb to inspect .. and as you look at it the right hand side pot is black ..
so i took top off and cleaned the bowls and jets ..  and reassembled .. only to find no change ??
it drives ok with little accerater pedal, but when i demand more it just bogs down , looses power/or wont increase .
anymore suggestions please??
its a twin weber on this bis
« Last Edit: March 18, 2010, 09:44:35 AM by bobblehead »
bobblehead
Re: bogging down ??
« Reply #4 on: March 18, 2010, 01:37:35 PM »
just noticed, what i believe to be the air mixture screw .. doesnt seat , it actually vibrates and undoes all the way out neally .
would this cause car to miss and bog like it is doing? . if so how can i make it seat ??
glue? blob of blue tack wedged in the hole ??
mixture screw at front of carb at bottom ???
bobblehead
Re: bogging down ??
« Reply #5 on: March 18, 2010, 08:04:41 PM »
video of the problem :
shed any light ????
bobblehead
Re: bogging down ??
« Reply #6 on: March 26, 2010, 06:22:06 PM »
ALL SORTED :)
AFTER SOME INVESTIGATION,  WHAT I CALL THE VACUM PUMP ATTACHED TO THE DISTRIBUTER WAS LOOSE, AND ON REVVING ENGINE MOVING POINTS ETC CAUSING CAR TO BACKFIRE .
CHANGED PUMP FOR A SPARE I HAD WITH 2 NEW BOLTS ..  YIPEEEE HE HE HE
SWEET AS .... MOT TIME NOW I RECKON
THANKS FOR ALL YOUR ADVISE AND HELP ... GLAD IT WASNT CARB OR ANYTHING ELSE ..
