Author Topic: BIS clutch pedal return spring - where does it go?  (Read 1336 times)
fly
« on: March 15, 2010, 10:21:20 PM »
My clutch pedal return spring has done one, can anyone shed any light (or offer up a photo) of where I need to put a replacement; the manual seems to suggest that it goes from the actuating arm in the engine bay to somewhere on the bell housing but I can't see where that somewhere might be. I can also see where a spring might go on the pedal assay but not where it would locate on the pedal itself. Help, pointers, photos, diagrams (basically anything idiot proof) greatly received.
Cheers, Ian
« Last Edit: March 16, 2010, 11:16:17 AM by fly »
Re: BIS clutch pedal return spring - where does it go?
« Reply #1 on: March 16, 2010, 01:10:38 PM »
Been up the old shed and I have a Bis bell housing there (not sure why just in case anyone needs one) . Took photo of the end of the actuating arm end with the small hole for the spring then you can see the slot on the housing where the other end of the spring fits  [-/
fly
« Reply #2 on: March 16, 2010, 01:46:54 PM »
Excellent, thank you. I assume then that the spring just hooks into the slot and through the arm?
« Reply #3 on: March 16, 2010, 02:56:07 PM »
Yes the fitting is pretty much the same across the range as I seem to have 500 , 126 a/c & a Bis bell housing here  [-/
