Problem solved!
I got the spanners out last Friday. On closer inspection, it appears that the problem was due to mud and dirt coming off my shoe over time, falling down around the base of the accelerator and getting drawn into the transfer tube that runs from the base of the pedal across the driver's footwell and into the central console. This had caused the linkage to stick over time. I suppose this is an inherent problem possibility with a floor-mounted pedal.
So I disconnected the throttle cable at the engine - the spring there is in good condition so nothing to worry about there.
Pulled back the carpet/mat in the driver's footwell and undid the two bolts securing the transfer tube to the floor.
Removed the pastic trim in the central console as far as the gear lever and pulled back the carpeting.Watch out for the little washers...easily lost if you dont have a good magnet or quick fingers.
Disconnected the throttle cable from the end of the lever. I then cleaned the pedal and tube assembley and applied grease to both ends. This allowed the linkage to rotate really easily within the tube with very little resistance. I then refitted the pedal, reconnected the cable at the throttle and took the opportunity to readjust the tightening on the accelerator cable as it had developed a little bit of slack over time beforehand (beware! if you do this on a freezing cold day, take into account that the cable may stretch a small bit in the heat...probably only a tiny bit though).
Back in with all the carpets, trim and mats and I fired her up...no automatic cruise control any more and definitely more responsive (which isnt a surprise to me now that the throttle closes when you take your foot off the accelerator for a change)
Overall time to fix - about 45mins from start to finish with freezing cold hands on the driveway
Thanks for the advice![/img]
