Fiat 126 Chat
BIS throttle pedal assembly
Pages: [
Topic: BIS throttle pedal assembly (Read 1722 times)
tiny126
Member
on:
March 03, 2010, 10:32:11 PM »
Evening,
Does the trottle pedal have a spring mechanism to help return it to the top or does the spring at the carb end do all the work? Mine stays depressed and I'm not sure it just needs greasing or I'm missing a part.
Rob
(getting close to MOT time
Subscriber VIP+
Re: BIS throttle pedal assembly
Reply #1 on:
March 04, 2010, 06:19:52 AM »
They do have a nasty habit of seizing up if a car has been standing for a while
Administrator
Reply #2 on:
March 04, 2010, 05:55:38 PM »
The bracket tends to rust if the car has been standing for a long time without use, Lift the carpet and spray wd40 or similar into the the end of the bracket where the acc" bar goes into the bracket on the floor and see if it slackens off, A few members have drilled a 1/8" hole in the centre of the bracket ( just going through the outer bracket) then you can keep it lubricated with a few drops of light oil
Pete.
il cavallo piccolo
Reply #3 on:
March 04, 2010, 07:01:32 PM »
if you find that the pedal is not returning then beware as it means the cable is about to give up the ghost! i found this out the hard way however if you have a bis you can do a quick fix and rig up a nice hand pulled accelerator cable.
tiny126
Member
Reply #4 on:
March 04, 2010, 10:29:18 PM »
Thanks for the replies [-/. I will grease up the pedal bracket and replace the cable.
Ta
Rob
Pages: [
Fiat 126 Chat
