Author Topic: Bis Battery light.  (Read 3912 times)
Bis Battery light.
« on: March 02, 2010, 07:39:17 PM »
Been out driving today and the battery light has started flashing at me.  Does this mean I need a new alternator or can it be overhauled?
Thanks!
Re: Bis Battery light.
« Reply #1 on: March 02, 2010, 07:41:27 PM »
MIght just be a wire or the brushes are worn.
I have a Bis altenator if you stuck [-/
« Reply #2 on: March 02, 2010, 08:22:49 PM »
When did you last check the tension on the drive belt  ???
If you have been driving around like I have recently , lights on & wipers going then it will cane the battery .
I am running on an old dynamo but alternators are well known for putting out your ignition light but not putting out enough juice if the belt is only slightly slack.
The flashing light means that you are fluctuating between charging & discharging,
Check the belt & give it a good drive in daylight on a dry day  [-/
Jan-in-UK
« Reply #3 on: March 02, 2010, 09:30:27 PM »
I would say brushes if the belt is tight. I had this problem million times years ago :)
www.fsoclub.co.uk
« Reply #4 on: March 02, 2010, 10:00:57 PM »
Tightened the belt recently but yes lights have been on a lot and blower for heater!
« Reply #5 on: March 03, 2010, 07:09:57 PM »
if the light is continually on then check that the small wire that is attached to the alternator is connected as i found this to broke regularly on all of my bis,s.
« Reply #6 on: March 04, 2010, 06:50:22 AM »
Thanks BIS 13 and everone else!  If it turns out to be bushes where can I get replacements?
« Reply #7 on: March 04, 2010, 05:50:25 PM »
Sent you a PM about possible leads but then I wondered if you meant brushes or bushes  ???
tony check
« Reply #8 on: March 04, 2010, 07:54:55 PM »
Check up a wire from the alternator to a starter. At me it has fallen off plus on a starter. Has soldered it and the lamp has ceased to blink
« Reply #9 on: March 08, 2010, 07:45:23 PM »
Thanks for all your advise, it must be some sort of bad connection because today it didn't come on at all </*
« Reply #10 on: March 14, 2010, 09:32:30 AM »
OK, had a look at the alternator and there is a problem.  The whole bolt/stork where the main red cable is attached is loose and wiggles about!  I need to take it off and have a closer look.  However, i did win this , thanks Rusty!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230444773747&
« Reply #11 on: March 15, 2010, 09:18:23 AM »
Odd to be bidding on one when I offered you one for free... ::)
« Reply #12 on: March 15, 2010, 05:47:31 PM »
Oh yes forgot about that :oops:  Maybe someone else can take it!  Thanks again for the offer!
Kent126
    • Facebook Profile
« Reply #13 on: November 20, 2010, 05:29:08 PM »
On this topic, because I didnt want to start a new thread;
Now I have replaced nearly all ignition parts including starter motor, cable, dizzy cap, condenser, ignition coil, plugs, rotor arm, and leads the car is running much better already. The battery is also new.
However I have noticed when I put my indicators on the battery light flashes at me, or when I slow down for traffic lights or roundabouts it seems like it wants to come on, but not quite. This is when driving with lights on. Is there a problem, or something else I should be looking at, or this this normal for the car?
I would like to replace or look at whatever is required sooner, and try to avoid another potential breakdown. :-)
Tom
1974 Italian Fiat 126 TA
2008 Fiat Panda 100HP
« Reply #14 on: November 20, 2010, 05:39:58 PM »
Check that you have enough tension on the alternator drive belt  [-/
