Author Topic: Can't get 1st and 3rd!!  (Read 1666 times)
jimbob4212
« on: March 02, 2010, 08:20:43 AM »
Hello,
I was driving down the road last night and when I moved away in first at some traffic lights the whole car juddered loads. I now can't select 1st and 3rd gear and the pedal is very low with only an inch of travel. Could this be just a clutch fault or something worse.
Cheers,
James
Re: Can't get 1st and 3rd!!
« Reply #1 on: March 02, 2010, 08:30:38 AM »
Is there any possibility that your whole engine & transmission has shifted backwards for some reason ? What are the mounts like ? If it had done then that would cause what you describe.
« Reply #2 on: March 02, 2010, 11:04:43 AM »
I'd start with gearbox mounts and gear linkages - I would think its not a clutch issue cos you would be getting it in all gears. past the external issues it may be you need to rebuild/ replace the gearbox as the 1st/3rd gears have gone west..
jimbob4212
« Reply #3 on: March 02, 2010, 01:08:35 PM »
Cheers i'll check it all tonight.
jimbob4212
« Reply #4 on: March 03, 2010, 05:53:35 PM »
Checked the mounts, they are all ok however the cable is very slack so this will require further investigation. Cheers for the help guys.
« Reply #5 on: March 03, 2010, 06:19:52 PM »
OK , trying to think outside of the (gear) box as removing and rebuilding that is a major opperation. Clutch repacement not so bad. But a loose clutch cable could be worn ,frayed & stretched cable. Damage can happen at the gearbox end if the outer cable is kinked. More common is the adjustor nuts. If they are not firmly locked then they vibrate loose so the clutch pedal gets nearer the floor.
Assuming the gear lever/linkage is in good order then that assembly bolts to the tunnel on slotted holes for adjustment , that could have slipped. Anybody checking this should make sure that you have large flat washers on the bolts. I just worked on a car that did not and the bolt heads had gone right through into the tunnel leaving the whole gear linkage floating free  ::)
« Reply #6 on: March 03, 2010, 07:05:36 PM »
try jacking the rear wheels off the ground and with the help of an assistant select gears by manually operating the clutch through the rear of the car NOT FROM UNDER THE CAR make sure that the car is not going to wobble or roll before you try this . if the clutch is okay it will engage with no problems ,i hope it is just the cable that has given up as thats an easy fix. another thing to check is remove the clutch cover (under the gearbox) and check that the clips on the thrust bearing are intact and both in place.
