Author Topic: Oil pan drain screw  (Read 1362 times)
Korius
  • aircooled 126 ' 97
Oil pan drain screw
« on: February 22, 2010, 05:35:27 PM »
Hello. I am interested to install an oil temperature gauge. But i dont know where to put the sender. I think that i can put the sender instead of oil drain screw through sender fitting adaptor. ( smth like that http://cgi.ebay.co.uk/VW-AUDI-OIL-TEMP-GAUGE-1-8NPT-SENDER-FITTING-ADAPTOR_W0QQitemZ350259122898QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item518d1212d2
So, what is the diameter of this screw? Maybe, this M14 X 1.5 adaptor diameter will fit?(like in this link)
Or maybe you have other ideas where to screw the sender?? sender diameter is 1/8NPT.
Thank you for help.:)
P.S. I have an aircooled 126, 97'
« Last Edit: February 22, 2010, 06:00:36 PM by Korius »
Re: Oil pan drain screw
« Reply #1 on: February 22, 2010, 06:53:04 PM »
Not sure what size thread it is. I can check in a few days as I'm not home just now.
How long will the temp sensor stick out?
If it's plugged into the sump plug socket then it will be pointing straight down and I'd be a bit concerned about it getting damaged hanging low from the bottom of the engine.
I would drill and tap a hole in the block close to the oil pressure socket, then you won't have to buy an adapter, but you will need the right tap size and you should do it with the sump off so you can contain the swarf.
Korius
« Reply #2 on: February 22, 2010, 07:39:51 PM »
It sticks out for about 1 cm.  So i dont think that it could be damaged very easily. In winter maybe when you are driving through  snow.
Other idea is just to remove sump and drill a hole at side of sump. :) and screw in the sender.
P.S. when you are removing sump you need a new gasket or you can use old one?
P.S.S. What is the thickness of sump sides?
« Last Edit: February 22, 2010, 08:10:41 PM by Korius »
« Reply #3 on: February 22, 2010, 08:55:40 PM »
I think the sump wall is about 2.2mm thick, its just sheet metal.
you won't be able to cut a thread through it.
You could tack weld a nut on the inside. You'll need a spring washer and loctite so it doesn't come loose
I would recommend having a spare gasket. I have managede to re-use them , but if it's not been changed for a while it will probably come off in chunks!
Korius
« Reply #4 on: February 24, 2010, 06:24:08 AM »
Quote
It is very good idea!! :) thanks.
one more question, It is good to have an oil temperature meter in aircooled?  Maybe i dont even need this.
