Author Topic: Fiat 126 lighter  (Read 1921 times)
Fiat 126 lighter
« on: February 17, 2010, 09:49:06 PM »
I just purchased an allegedly original 126 lighter from ebay. I do not smoke but will be used to charge or power ipods and stuff. May seem like an obvious question but do I simply attach the positive wire (live) to another live wire connection? It does not really matter which live connection, right? The other wire, I simply screw it into the bodywork or to an existing ground connecton?
Re: Fiat 126 lighter
« Reply #1 on: February 17, 2010, 10:03:06 PM »
There should be the cigar lighter wire there already the live also feeds the radio, Just have a hunt round for it :D
« Reply #2 on: February 17, 2010, 11:58:23 PM »
Many thanks. I'll be making the hole for lighter gizmo and will look around for the wire after I remove the fan/heater control panel. Presume the lever ends for the heater etc. can simply be pulled off whilst the face/panel can be removed via the two screws. I wish there was a Haynes manual for the Bis.
« Reply #3 on: February 18, 2010, 01:30:55 AM »
I bought an aircooled haynes manual off Ebay for less than a fiver just for reference, everything is the same except the engine, cooling system and electrical system. But you have access to these in the subscriber section ;)
HAYNES HAVE REPRINTED THERE CLASSIC FIAT 126 MANUAL 1973-1987 (No 0305) ALTHOUGH ITS A BIT PRICEY AT 25 QUID
« Reply #4 on: February 18, 2010, 08:57:06 AM »
I have fitted one and the wire is there, it just pushes straight on to the rear of the lighter!
« Reply #5 on: February 18, 2010, 02:38:07 PM »
 :) The only modification on my Fiat 500 when I got it was the fitting of electric screen washers. This left the original little rubber pump which is in a discrete position hanging under the dash. I tried to remove it but could not get to the mounting screws then I realised that the hole where the pump went would be just about perfect to fit a cig lighter. So going to do that then I can plug in my Tom Tom , that is an electric drum I beat with a slow rythm when stuck in traffic  :oops:
