Author Topic: Please help.  (Read 1412 times)
Vaz
Please help.
« on: February 14, 2010, 09:46:29 PM »
Hello!I'am from Latvia and I want to buy Fiat 126. In my country I have never seen this car, but there are a lot in Poland. Please tell me which problems can I meet during the exploitation and repair? Thank you.
Re: Please help.
« Reply #1 on: February 15, 2010, 04:23:37 PM »
Hi. Many have asked similar questions(you can find them on the forum) and there are a few problems with them mainly due to poor maintenence:
Rust, check wheel arches, sills etc for rust. Then there's the suspension, make sure the brakes and steering operate. It's important to grease the king pins regularly. Another is the gearbox, might be loud or hard to change gears, an oil change might cure this. Check electricals, problems usually arise from wire/terminal corrosion, a quick clean helps. I can't say that there are problems with the engines: they're built well. Check out for oil leaks though and if you want good heating then check the thermostat housing and connecting pipes.
Happy 126 hunting  ;D
