The last proper run out I had in my little motor was on Boxing Day , partly because of the weather and also the engine was running strange & I did not fancy freezing my cashews off as I wait for breakdown recovery. I can only describe it as a misfire but quite strange. When warmed up the engine ran a bit like one of those stationary engines at a Steam rally , spitting & coughing now and again on tickover , power a bit down & also missing at higher revs & speed. I checked & reset a few things but it was a puzzle. Started up today and went round the block a couple of times & problem still there but then I looked at the online fuel filter
Small trace of rusty water in the lower corner
So I guess that at £1.12.9 per litre it is worth BP , Shell & Texaco sneaking in a little H2O which probably does not show on a modern motor but does on a little 2 cylinder job.
OK , conspiracy theory but I have definately picked up some dodgey petrol
