Author Topic: Big problem...  (Read 2331 times)
Josip
    • JoeXmas Photo
Big problem...
« on: February 13, 2010, 02:44:05 PM »
It is a problem in the '86 Fiat 126P, below exhaust it a screw with a hole in it's head. First off the problem is that the same one is in the back of the engine to which it is difficult to get ... the second and main ... In fact the car I was driving lost compression and first I thought that I had a hole in the pipe at the exit from the machine to the sound that was terribly loud, even I put hand behind and I felt hot air exhaust (at least i was thinking so) from who, after I put the cloth on the exhaust i was thinking ... ok if it is punctured and if I put the cloth and the car still runs its definitely a hole in exhaust pipe ... However, problem is at the screw in the back which is located below the pipe, in fact now I can not turn on the car, and that i can hear and feel air that goes out if. Car has no compression and car can not turn on ... Please help!
Re: Big problem...
« Reply #1 on: February 13, 2010, 04:20:18 PM »
It's probably a blown head gasket!
The screw that you are referring to is a safety device, when the head gasket blows the pressure is relieved through this screw.
Josip
    • JoeXmas Photo
Re: Big problem...
« Reply #2 on: February 13, 2010, 04:29:43 PM »
Thats what I am afraid of... that is a lot of time to fix it....
Re: Big problem...
« Reply #3 on: February 13, 2010, 04:37:23 PM »
it's not to bad of a job.
Here is a diagram of the safety valves.
Josip
    • JoeXmas Photo
Re: Big problem...
« Reply #4 on: February 13, 2010, 05:15:30 PM »
Well... it can be problem in valves too, maybe they are not set up how they should be?
Re: Big problem...
« Reply #5 on: February 13, 2010, 05:31:23 PM »
unlikely :(
the grooved area is filling up with gas and the only time this happens is when the head gasket is leaking
Josip
    • JoeXmas Photo
Re: Big problem...
« Reply #6 on: February 13, 2010, 05:34:58 PM »
...altho on one forum i got interesting answer, it might be temperature regulated fuse, a screw hole is filled with lead or alloy or some kind to protect engine from overheating. If in some reason engine over-heates this alloy or lead thing melts and compression comes out so engine can stall... it reduces the possibility of greater damage...
Re: Big problem...
« Reply #7 on: February 13, 2010, 06:23:24 PM »
Those bolts are hollow.
exhaust gas is vented through them when the head gasket is blown I'm afraid!
As Chris said its not too bad a job to do either.
