DECIDED TO TRY AND DO A HOW TO GUIDE TO GREASING KINGPINS ON A 126 BIS .
FIRST OFF GATHER TOOLS :
JACK
PEICE OF WOOD
BLOW TORCH ( INCASE NIPPLE BLOCKED OR SEIZED )
SET OF GRIPS OR A 7MM SPANNER TO REMOVE NIPPLE TO CHECK ITS WORKING
GREASE GUN
WHEEL BRACE
NEXT OFF LOOSEN OFF YOUR WHEEL BOLTS :
THEN POSITION JACK UNDERNEATH FRONT OF CAR, WHERE THE LEAFE SPRING IS, AND COMMENCE JACKING
UPWARDS WILL BOTH FRONT WHEELS OFF THE FLOOR
THEN UNDO ALL THE WHEEL BOLTS ON BOTH WHEELS AND REMOVE THE WHEELS .
YOU SHOULD SEE SOMETHING LIKE THE ABOVE PICTURE .
NEXT LOOK FOR THE GREASE NIPPLE HERE WAS AND IS MINE :
CLEAN NIPPLE WITH A RAG OR SOMETHING, THEN CONNECT YOUR GREASE GUN AND COMMENCE GREASING, TURNING THE STEERING WHEEL OR RACK UNTIL GREASE SQUIRTS OUT BOTTOM ON KINGPIN/STUB AXLE
PUT WHEELS BACK ON TIGHTON THE WHEEL BOLTS JUST A TOUCH
DROP CAR DOWN OFF THE JACK AND TIGHTN YOUR WHEELS BACK UP FULLY .
ABD THATS YOU DONE
