Author Topic: Break drum removal  (Read 2667 times)
Break drum removal
« on: February 12, 2010, 08:13:32 PM »
Gone to remove the dums on the rear, is it true that the little holes to fit a puller to are M9?
Re: Break drum removal
« Reply #1 on: February 12, 2010, 11:16:59 PM »
Think they are M10  :oops:
« Reply #2 on: February 13, 2010, 07:40:06 AM »
Wentto an engineering supplier and M10 would not fit, tried an m9 tap and it went in but he has no m9 bolts cos it is an unusual size?
« Reply #3 on: February 13, 2010, 07:49:36 AM »
I think that it is a case of getting the right pitch thread on an M10 bolt  [-/
« Reply #4 on: February 13, 2010, 12:08:34 PM »
Right, took it back to the engineering shop and tried all sizes of M10 and they are too big, it is deff M9 as M8 is also too small.  Guy said that the automotive industry use obscure type bolts because when you go in they wan't to sell you a new hub!
Gonna try and get some on Ebay!
« Reply #5 on: February 13, 2010, 02:55:39 PM »
If the drum is seized then a final alternative maybe to fit the wheel onto  the hub and try to knock it off with a large hammer by hitting the tyre and rotating the wheel at the same time. Best to use a wheel with a worn tyre and to be careful not to hit the wheel rim.
« Reply #6 on: February 13, 2010, 04:09:32 PM »
Thanks for reply but surely this can't work as the wheel bolts through the hub.
« Reply #7 on: February 14, 2010, 05:17:09 PM »
 Yes that is true.  :oops: Now you mention it i had done this on a car that had the wheel studs on the drum and used wheel nuts. This still can work if you need to take the hub off as well...
« Last Edit: February 14, 2010, 05:18:45 PM by GTMaster »
« Reply #8 on: February 14, 2010, 08:33:25 PM »
I have removed them in the past by hitting the drum on the edge with a hammer.
Left side, then right side in turn which should push the brake shoes together and reduce the force holding the drum on.
I've never found a drum that couldn't be removed with10 minutes hammer persuation!
Jan-in-UK
« Reply #9 on: February 14, 2010, 08:46:40 PM »
Michael is right. Plus few hits from behind can also do the job easier :) hummer - most universal tool of all.
www.fsoclub.co.uk
« Reply #10 on: February 20, 2010, 04:04:42 PM »
i too live in the hammer camp also if you are getting new shoes at the same time a little help with a screwdriver.
neilW
« Reply #11 on: March 15, 2010, 03:04:03 PM »
is this a common problem??as mine are starting to stick. its happened twice in the last 10 days. they got so hot by the time I noticed, (on a motorway), i had to pour water on to cool them down, was like pouring water into a roasting hot pan on the hob. SIZZZZLE!!
« Reply #12 on: March 15, 2010, 03:19:13 PM »
Are you talking about fronts & rears or just rears. If the brakes are binding all round then the master cylinder would need looking at. If it is just the rears then could be handbrake not releasing correctly or seizing wheel cylinders  [-/
landyman
« Reply #13 on: March 15, 2010, 08:11:09 PM »
fine adjustment tool No.1 always works, if not use fine adjustment tool No.2 [the bigger hammer] or manchester screwdriver. </                         :oops2: giving away trade secrets now
