Author Topic: new family member bis ..  (Read 1351 times)
bobblehead
  • monkeys on the move ..
    • my fiAT 126 PICK UP
« on: February 06, 2010, 03:58:25 PM »
hi there we have just aquired another fiat 126 bis , its been driven and parked in a garden for the past 4 years and not touched , i tried starting it today using jump leads, it turns over but wont run ??
it has a inline fuel filter, and i can see that is bone dry ??? .. i have put fuel inside tank , so it cant be pulling through ?? unless it has a airlock ??
checked points, they are clean ... did not have have not checked plugs or coil ..
any ideas? i want to get it running so i can get he heater on and dry the car out, as its been open to the elements .
anyhelp and advise would be great ..
also if i wanted to check plugs, how on earth do i get in , at them ??
oh and another thing, i squitreted and also dropped petrol down the carb , and it still wouldnt fire ???
help please lads @_)
Re: new family member bis ..
« Reply #1 on: February 07, 2010, 07:22:52 PM »
It could be the fuel pump.
Try taking the pump to carb pipe off at the carb end and place in a jar. When you turn the engine over it should fill up with fuel.
To check if you have a spark, pull the plug lead off at the spark end and using a spark plug socket (16mm I think) remove the plug. I have never worked on a BIS engine so I don't know how awkward they are to get to. re attach the plug lead to the plug and hold it against the block (USE A WELDING GLOVE!!!) and as you crank the engine it should spark.
these simple checks should help point you in the right direction.
Michael
bobblehead
« Reply #2 on: February 07, 2010, 08:23:12 PM »
thank you ....  i swopped out the fuel pipes from the tank , and took fuel filter off cleaned etc adjitatted it a bit .. cleaned points ... and fuelled up .... and she a minter . like a singer  ....
thanks for all your help .
now needs welding torch .. he he  .
