Author Topic: Bis Towbar  (Read 1579 times)
Bis Towbar
« on: February 05, 2010, 10:53:52 AM »
The towbar I bought has been fitted for a while now and all seems to be ok apart from one thing.  When it was first fitted the engine rocked around so much that it hit the towbar and made a god awful noise.  This was due to worn out gear box mounts and engine mount, so replaced these and all is fine.  However, when the rear end hits a bump in the road or I go too fast over a speed hump there is a loud bang from the rear.  The tow bar is bolted to the suspension pivot bolt and the noise seems to be coming from that area!  Do you think that I may need new shocks and spings?
gsxr126
Re: Bis Towbar
« Reply #1 on: February 06, 2010, 12:11:06 AM »
Hi Ciao,
I recently replaced my RHS control arm and found that the were two 'shims/spacers/washers' on each side of the arm where it bolts into the chassis. Have a look at that area as not including these shims would cause that kind of noise.
Re: Bis Towbar
« Reply #2 on: February 06, 2010, 09:46:36 AM »
Thanks I shall check it out.  Just has a thought maybe I am missing a bump stop on the suspension!
Re: Bis Towbar
« Reply #3 on: February 08, 2010, 06:05:42 PM »
Turned out to be the engine mount.  Bought a new one but only aircooled ones are made, the Bis one raises the engine by another 10mm.  All was not lost though I used the old Bis bushes but used the new spring from the aircooled mount as it is the same.  No knocking at all now!  Very happy! :D
