Author Topic: Do BIS engine blocks crack after head gasket failures?  (Read 2528 times)
tiny126
« on: February 04, 2010, 09:30:10 AM »
Good Morning,
I bought a BIS with head gasket failure thinking it would be a quick afternoon session changing it. I have changed it but before it's even turned over properly, one cylinder and the inlet manifold was full of water.  So my question is do the blocks generally crack when the gasket fails? Does anyone have a BIS engine for sale?
Rob
Dan_535
Re: Do BIS engine blocks crack after head gasket failures?
« Reply #1 on: February 04, 2010, 02:14:23 PM »
i have an aircooled so dont know too much on the BIS, fair to say if the engine overheated badly enough and was under load at the time that its more than likely though to crack the block as well.
Just spotted this on e-bay...
http://cgi.ebay.co.uk/FIAT-126-BIS-ENGINE_W0QQitemZ120525038105QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item1c0fda2219
« Reply #2 on: February 04, 2010, 06:52:47 PM »
Hi Rob. When you replaced the head gasket.
Did you have the head pressure tested for cracks ???
Did you have the head skimmed flat, they tend to warp when they have overheated ???
Also did you turn the engine so the pistons are at the bottom of the stroke so you can inspect the the bores for cracks,
You can tell if their is a crack as they usually have a dark water stain on the inner walls of the liner.
tiny126
« Reply #3 on: February 04, 2010, 06:58:54 PM »
Cheers Dan.Hope I win it. I'm baffled why the inlet manifold was full of coolant. Rechecked the head and the block and there's no obvious explanation.
Pete; I didn't get it pressure tested or skimmed. I check the head with a flat edge and it looked fine. The bores appear to not have any cracks but there are dark stains. I think the best bet is to go with the engine on fleabay.
Thanks for all your help.
Rob
tiny126
« Reply #4 on: February 24, 2010, 06:31:14 AM »
Finally collected the engine on Saturday. It was located in Dorset and I live North Wales ! There is compression so we will see what happens. It came with a nearly new coil and HT leads, fuel pump and a fairly fresh looking clutch. On the down side the oil doesn't look as if it has been changed for yonks. So I drained it as best I could and cleaned out the oil filter. I fitted it yesterday so today I will fit the exhaust, fill it with fresh oil, coolant and petrol. Fingers crossed it works!
RSPSTEVE
« Reply #5 on: February 24, 2010, 08:23:28 AM »
Let us know how you get on , good luck
Steve
tiny126
« Reply #6 on: February 25, 2010, 10:38:32 PM »
Well the engine is in and a brand new battery is fitted and it won't turn over  :cry:  . There is no noise at all when the ignition is in the start position. I am not sure if the starter has suffered damage due to the old engine hydraulicing (if that's how you spell it). I did check the starter by giving it a direct feed and it span up. I am not sure where to check now, eg fuses wiring etc. Any advice would be appreciated.
Ta
Rob
« Reply #7 on: February 25, 2010, 11:03:40 PM »
Have you connected the small wire with the spade terminal to the solenoid ??? if yes check to see if you have a 12v supply on the small wire that connects to the solenoid with the ignition on and the key turned to the start position you should have 12v.
« Reply #8 on: February 26, 2010, 11:31:37 PM »
Check the Terminals as Pete126 suggested.
Nothing you have changed will have effected the battery or starter.
As you have changed the engine youmay have overlooked one of the starter wires or the main earth strap.
Michael
tiny126
« Reply #9 on: February 28, 2010, 09:38:59 PM »
Hi Everyone,
Thanks for all the replies. I managed to get the engine started on Saturday after cleaning the old plugs and using a bit of easy start, it's not smokey and doesn't rattle too much which is nice. The starter motor problem is intermittent, I went to the car on Saturday and the starter engaged and did so about 40 times then the problem started again, Turn the key and nothing. I bump started it today and now the starter is working again. I think the lead to the solenoid is faulty, either loose connection at the starter end or at the ignition end. I have also discovered another problem with the throttle peddle. Once it is depressed it doesn't spring back. I think there is a part missing at the cable link side of the peddle bar. Does anyone know if there should be a spring assembly attached to the throttle pedal?
So far so good [-/
Rob
tiny126
« Reply #10 on: February 28, 2010, 09:51:23 PM »
Also, any tips on bleeding the coolant system properly and changing the points?
Ta
Rob
