Author Topic: water leak  (Read 2339 times)
massa
water leak
« on: February 03, 2010, 07:51:52 PM »
hello had all types of italien cars over years now gone against my own mind by chancing a bis bought her of ebay drove back home 250 miles no hint of bother fan switch is manuel which gives more confidence anyway i have a water leak coming from bottom of engine in from stat housing there seems to be a little cut out as if it is designed to emit something i flushed system and topped up with anti freeze and distilled water have i put to much in is it a overflow ? car runs superb thanks chaps  dave the massa fan
Re: water leak
« Reply #1 on: February 04, 2010, 04:31:25 AM »
Hi Dave. Welcome to the forum :D
There should not be any water leaks coming from the thermostat housing, I'd drain the water/antifreeze into a bowl so you can use again, take the pipes off and check the ends aren't split, also check the casting. It has been known for them to rot if the car has been stood and of the road, if it has still got the thermostat in take it out and chuck it.
If the thermostat gasket is broken its easy to make one using the cardboard from a cereal packet, as for overfilling the water will blow out through the radiator cap. The correct way of filling the system is, turn the ignition on, the top right hand warning light should be on when there is no water in the system, fill the radiator up until the light goes out, start the engine until warm and bleed the system at the front (the tube on top of the heater box) and at the rear the nut on top of the radiator where the top pipe goes into the rad. it will take a while for the level to settle down but just top up till the warning light stays off.
massa
Re: water leak
« Reply #2 on: February 04, 2010, 04:38:53 PM »
thanks pete if you take the actual stat housing and came inboard about away from stat about 2 inches there is a small what i would call a exit from base of engine at the very back of stat housing gasket is fine as are hoses this exit hole is only a little nick must be designed for something to emit from it good or bad thanks for replying
Re: water leak
« Reply #3 on: February 04, 2010, 06:30:47 PM »
If its leaking from Here.
It must be the seal behind the water pump impeller.
massa
Re: water leak
« Reply #4 on: February 05, 2010, 06:59:15 PM »
you are a saint thats exactly where its leaking so thats a new pump then ye to get to it stat housing must come of ye pump behind it then thanks again  ricambio will do a pump i suppose
Re: water leak
« Reply #5 on: February 05, 2010, 07:56:54 PM »
Its the water pump packing box ;)  This might help
massa
Re: water leak
« Reply #6 on: March 28, 2010, 01:05:13 PM »
hello wonder if you can advise finally getting round to doing leak got cover of in front of me is a impeller take it that water pump seal is behind it what is best way to proceed to renew seal thyanks again dave
Re: water leak
« Reply #7 on: March 28, 2010, 10:22:40 PM »
Yes its behind the impeller just remove the allen bolt, I have never taken the packing box and oil seal out so can't advise the only place i have seen them on line is ricambio international on ebay, give them a ring and ask if they know how it comes apart and what sort of job it is.
massa
Re: water leak
« Reply #8 on: March 29, 2010, 05:40:05 PM »
thanks pete will do that
