Author Topic: Air Cooler with a Panda 30 Head  (Read 2219 times)
jon.hunt
« on: January 27, 2010, 12:53:09 PM »
Hi All,
          I Am having great difficulty getting the Heater to work with a Panda 30 Head!!!!  I tried butchering the ordinary  thermostat housing to fit but I could not get it to work as the Flap hit the Didtributor. So I ordered at Great expense a Genuine Panda 30 Thermostat shroud which Fits great on the Head, But there is now no covering over the Cylinders so all the Hot air just Blows away, I assume there must be a Covering Here on a Panda 30?  If so what part do I order now Please,  ANY Help Greatly appreciated by anyone who has fitted a Panda 30 Head Please.
                                   Jon.
Re: Air Cooler with a Panda 30 Head
« Reply #1 on: January 27, 2010, 08:50:46 PM »
All the panda 30 conversions I have seen have had no heating.
« Reply #2 on: January 27, 2010, 09:39:32 PM »
John I cut the panda head to fit the 126 tinware, I have seen panda heads with modified panda heater box.
« Reply #3 on: January 27, 2010, 09:59:39 PM »
John found this photo of modified heater box
« Reply #4 on: January 27, 2010, 10:01:06 PM »
and another view
Tomasz
« Reply #5 on: January 30, 2010, 10:07:58 AM »
I modified the original but my welding was awful back then and it ending up shaking itself to bits.  Worked while it lasted though! Might have a picture somewhere.
Alfons1972
  • sorry for my bad english...
« Reply #6 on: March 12, 2010, 05:43:37 PM »
the engine in the picture above is not a modified Panda 30 but is a complete german Fiat-126-engine...  ;D
(look at the carburator)
just look in ebay.de, there will be such housings from time to time...
Fiat 500 R
Fiat 500 giardiniera
Alfons1972
« Reply #7 on: March 16, 2010, 06:38:15 PM »
now I know what you need:
that's a pic of a Panda30-engine. As far as I know, there is a little screw in the cylinder to fix that tin.
The problem is that you probably will not get those parts... so you will have to produce it yourself...
Fiat 500 R
