Author Topic: Timing Bis  (Read 1736 times)
Timing Bis
« on: January 23, 2010, 10:26:05 AM »
When timing it says line up the first notch, now is this the first pointed bit or the first nick, it is not too clear on the diagram it just seems to point ramdomly at location 2!
Re: Timing Bis
« Reply #1 on: January 23, 2010, 03:15:28 PM »
OK I think I have done this correctly.  I removed the vac tube and timed it with the strobe, the two marks lined up.  When I reconnected the vac tube the marks did not line up and were seperated but engine ticks over nice!
Is this correct?  (Never done it B4 you see)
Re: Timing Bis
« Reply #2 on: January 23, 2010, 06:14:49 PM »
As the photo to the bottom of the notch, Once you reconnect the vacuum advance pipe it will be slightly out of alignment [-/
Re: Timing Bis
« Reply #3 on: January 23, 2010, 06:20:33 PM »
Thanks Pete [-/
