Author Topic: 126 solonoid starter  (Read 1490 times)
saviogimmi
« on: January 19, 2010, 11:09:52 AM »
Can anyone here help, i am putting a late 126 engine in my fiat 500, which has the old pull type starter, the new 126 engine has the solonoid starter.  The question is how do i wire it , it has 3 connection at the back one spins the starter which is a bolt on connection, a small spade type conector which engages the solonoid, then i have one bolt connection left what is it is it for an earth strap??.
Anyway how does it wire up, i was thinking that i need to run a cable to a push button starter from the batt+ then out of the pushbutton to the bolt connector that turns the starter, then also connect the solonoid to this too so that they both fire at the same time???
Re: 126 solonoid starter
« Reply #1 on: January 19, 2010, 07:21:31 PM »
 (-* to the forum :) Run the solenoid wire from the ignition (live when in the RUN position) switch = starter button = to the solenoid.
Use a heavy duty push button 10amp+ or you can use a standard button with a relay.
