Author Topic: Flat spot on acceleration  (Read 3062 times)
« on: January 13, 2010, 07:00:23 AM »
My Bis has developed a small flat spot just as you start to accelerate then it picks up again.  Dose this mean that the carb may need rebuilding - cleaning, new gaskets?  Also can you get a gasket set anywhere else than Ricambio as they are a little pricey!
Re: Flat spot on acceleration
« Reply #1 on: January 13, 2010, 10:29:13 AM »
Check ignition timing first and check advance mechanism is working properly.
« Reply #2 on: January 13, 2010, 11:41:08 AM »
Check points gap as well. Everything is expensive at Ricambio , it might be worth contacting Webcon if you google them . What is the Weber fitted on the Bis by the way? I would be interested in having a look at one if anybody out there has a knackered old one. It would be interesting to put one next to a Weber 30 DIC, compare parts , jets , etc.
fly
« Reply #3 on: January 13, 2010, 12:10:17 PM »
There's a fella selling gasket kits on eBay, I think I saw he did a complete carb service kit with spill tray and everything.
Is the bis not a 30 DIC?
« Reply #4 on: January 13, 2010, 04:23:27 PM »
Weber 30 DGF on a Bis it seems . Very interesting old thread on Preloved.co.uk forum , extract shown below ...........
"I have been told that the Panda 30 version of the Bis 30 DGF has larger venturis and coupled with the Panda camshaft should give more than 30bhp in the Bis engine - if the standard exhaust doesn't strangle it. I am not having any luck with finding a 500Station Wagon Abarth exhaust, so I will try making a free flow exhaust from a couple of 'Cherry Bombs' (see the 126 tuning page on the Blitz Racing site). Another carb to try is the Weber 30 DIC as used on the Fiat 850 Sport Saloon/Coupe/Spyder. The later versions have 23mm venturis in both barrels the same size as the venturis in the standard 652 motor ! As the Bis head has twin inlet ports (like the 30bhp heads), I am going to try twin carbs on a new inlet manifold. Contenders are twin 28 IMBs from the 652, twin Solex 30 PIB4s from the Fiat 850, or as favourite, twin Dellorto 30/24 (or32/28) carbs. I have found one of these Dellortos so far but might never find a second. I have a Nardi cam that I bought more than thirty years ago for my 500 and if it fits the Bis I could fit a 32DCOF twinchoke side draught from a Fiat 124."
« Reply #5 on: January 13, 2010, 05:16:06 PM »
I have two of the weber 30 dgf but on both the choke lever is broken so this won't help, I will post a pic and see if you guys know of any way to repair it.
I have never stripped one down, so this weekend I shall strip the one not on the car and throughly clean it and check it, then swap them over and see what happens!
Here is the offending item, it operates the plates at the top of the carb
(Sorry about the quality of this image, other cam needs charging)
« Last Edit: January 13, 2010, 05:37:00 PM by ciaoflyer »
fly
« Reply #6 on: January 13, 2010, 10:03:29 PM »
Oops sorry, yep, DGF...not getting much sleep.
If you dont get any joy with the carb let me know - ive taken mine off and fitted a dellorto IDF, i havent run the car with it on yet and its likely to be a couple of months till everythings up n running, but if all's well ill let the DGF go to a good home.
Had a look on ebay but can only find the ricambi service kit, could have sworn I saw somebody else flogging them.
Going onto that thread on preloved, I read that some time ago and there's a suggestion from the guy in Jersey about putting a bolt in the slide on the throttle - I did it and it improved the pick up no end, I think mosly because petrol was pooring in at a rate of knots, but as a free mod cock on.
« Last Edit: January 13, 2010, 10:37:02 PM by fly »
« Reply #7 on: January 14, 2010, 06:58:32 AM »
Would like to see a pic of this fitted!
« Reply #8 on: January 20, 2010, 10:14:28 PM »
did you fix the flat spot? i had it once on my was a split diaphram.
Regards
« Reply #9 on: January 23, 2010, 06:08:14 PM »
Cheers guys for all your input, she is now running sweeet!  Wasn't carb after all so gonna leave it aloan for now.  It was the timing!  Re gaped points, used strobe to get the timing spot on and the flat spot has dissapeared, it also accelerates much better aswell.  We had trouble along the way in the form of the engine mount bolt, only removed it so I could clean out the oil filter!  Anyway, clean oil filter, new oil, timed and modified engine bolt that seems to be working!  Happy days.......for a little while anyway!  What will she throw at me next! [-/
