Author Topic: gear lever  (Read 3091 times)
The Doctor
gear lever
« on: November 15, 2005, 09:20:52 PM »
:D Hi every1
my gearlever rattles a lot - is it possible to (a) make it shorter (b) fit a better rubber boot than the standard, and (c) how difficult is it to remove the gear change mechs to lubricate, etc.? :?:
thanks
Graham
you can do it in a 126 (I have!)
toz
gear lever
« Reply #1 on: November 19, 2005, 08:07:29 PM »
hi does the gearbox whine?and is there olot of movement from the gearbox?
The Doctor
gerlever
« Reply #2 on: November 19, 2005, 08:12:07 PM »
HiToz - nope, the gearbox makes no sound, nor does it move about.  But the gearlever rattles unless I hold it hard against plate holding the rubber boot, especially when accelerating.  Also, I am able to turn it up and down as if tightening it, but it never seems to get either tighter nor looser :!:  :?:
Graham
toz
gear lever
« Reply #3 on: November 19, 2005, 08:29:32 PM »
is your rubber gator spit at the bottom of the shaft??
