Author Topic: Engine coolant/anti-freeze  (Read 3302 times)
« on: January 03, 2010, 10:26:39 AM »
Happy New Year!! Is there any way of checking whether my 126 has anti-freeze? I drove my car last weekend (morning) after the snow spell (but still freezing at night) and not having been driven for three weeks. It started fine but after driving a couple of miles, I noticed that the coolant warning light flashed very occassionally but the engine coolant temperature gauge was less than centre (left), so it was running normally. However, the occassional blinking eventually stopped. I was wondering why the coolant warning light was blinking albeit very occassionally. Could it be that the car do not have anti-freeze or coolant (i.e. just normal water)? Does the sensor need replacing?
Re: Engine coolant/anti-freeze
« Reply #1 on: January 03, 2010, 10:34:42 AM »
No it just means that it needs topping up a little.  When the car warms up the coolent expands going above the sensor and putting it out, well I think that's right.  Anyway if you are not sure about your coolent mix, drain it and replace with 50% antifreeze and 50% de iornised water.
« Reply #3 on: January 03, 2010, 11:56:48 AM »
its more expensive but try using the coolant that is not meant to be diluted (its orange in colour) from halfords. this will also mean that the internals of the cooling system will not get all scaled up.
defender90
« Reply #4 on: January 03, 2010, 12:10:32 PM »
  If your engine had been frozen the water pump wouldn't have turned and you would have heard your belt squeling, as mentioned your water level is a tad low but as you are obviously not sure of your protection level you need to do as the others suggest and replace your coolant now with as stated 50/50 or the excellent suggestion of Biz13
  Of course if you'd bought the Air cooled model you wouldn't have this Problem! Da da!
Sorry could'nt resist   ;D
Kevan
Radcliffe
Gt.Manchester
Citroen BX TDG (soon to go)
Citroen BX TZD
Land Rover 110 Station Wagon
« Reply #5 on: January 03, 2010, 12:37:02 PM »
YAWN! :D
« Reply #6 on: January 03, 2010, 06:51:51 PM »
Many thanks to everyone. I will ge the Halfords antifreeze tester. Is replacing the coolant easy or do I need to book my car to a Fiat specialist or dealer?
« Reply #7 on: January 03, 2010, 07:05:27 PM »
Easy mate, I do it like this....(although I am not sure if it is the correct way)
1. Get a bowl to catch the water
2. Disconnect the big pipe that goes to the Thermostat housing all the water/antifreeze will come out        hopefully into your bowl
3. Squeeze the big pipe on top of the engine to get out any remaining water.
4. Mix up your new water/antifreeze
5. Reconnent the big pipe to the therm housing
6. pour the new mix into the filler cap on the left hand side of the boot area.
7. Keep pouring it in until the light on your dash goes out (the one that was flashing)
8. Squeeze that big pipe again and you may find the dash light comes on again if so top up a bit more.
9. Now warm your engine until the thermostat opens, under the front bonnet there is a small tap connected to a red pipe on the drivers side, you have to open this with the engine running to let out any air in the system.  Now this last part I am not sure about but it is how I do it and you have to be careful because the water coming out the tap is VERY hot, when it comes out retighten the tap.
10. Sit back and nurse your burnt hands.
If anyone else has any ammendments to the above please say cos I'd love to stop burning my hands!
Good luck!
« Reply #8 on: January 04, 2010, 12:06:48 AM »
another method is get a helper and then sit in the car as it is running and let THEM burn their hands.....
« Reply #9 on: January 04, 2010, 01:20:54 PM »
Well the way i've changed coolant on a car before is like this:
If there's a tap or screw/bolt with which you can drain the coolant from the radiator then use that or disconnect a pipe on the radiator. Some Fiat engines also have a bolt on the side of the engine block from which the coolant can be drained from. Have the heater open, unscrew the radiator cap or expansion tank cap so all the coolant drains out.
After putting back the pipe or bolt open up the bleed screw (if there's one) and start filling up the expansion tank or radiator with coolant and ionised water (whatever concentrate you prefer), at the same time squeezing the pipe. When only coolant starts coming out of the bleed screw/bolt (not bubbly) then close it. Start the engine, wait for it to warm up to normal temp (when fan switches on) and top up if needed. Any small amount of air that might be in the system will come out through the expansion tank.
It's handy to know how much coolant is needed in your engine (e.g Haynes manual) 'cause then you can check how much you have poured into the system and also how much more you might need.
That's all i can think of from the top of my head, it's been about two years since i've changed coolant on a car :)
« Last Edit: January 04, 2010, 01:26:26 PM by GTMaster »
