Author Topic: Early Fiat 126 12"steel wheels  (Read 5165 times)
ianhowe
« on: December 30, 2009, 01:04:51 PM »
Has anyone got a set of early Fiat 126 12"steel wheels with the large PCD,also on Fiat 500R.
As seen in this photo www.velocetoday.com/images/august07/fiat-book-126.jpg
Please email ian on [email protected] or phone 07894687305.
« Last Edit: December 30, 2009, 04:19:32 PM by ianhowe »
Re: Early Fiat 126 12"steel wheels
« Reply #1 on: December 30, 2009, 03:58:55 PM »
Out of interest the ones fitted to the 500R are narrower than the early 126 ones.  [-/
ianhowe
« Reply #2 on: December 30, 2009, 04:11:17 PM »
Thougth they where 4.0 x 12".
« Reply #3 on: December 30, 2009, 05:04:13 PM »
I thought they were all the same and bought a set which are wider and heavier construction than a standard 500 wheel. But I measured a set on a standard 500R that turned up at a rally and the rim width was the same as the standard 500. I also believe that a wider set was mentioned on a forum this year and it was suggested that they were an Abarth special part.
ianhowe
« Reply #4 on: December 30, 2009, 05:13:51 PM »
Thanks for the info,are the ones you have 4.0" wide & where did you buy them?
« Reply #5 on: December 30, 2009, 06:10:38 PM »
They were just an item that I went for on eBay one day , they turn up from time to time. They are the 126 width which is 4" across the inside of the rims. Some of the later 500 modifications and the early 126 developements still seem to be a bit of a mystery as I found out when I bought a front brake drum that I thought was 500 but I discovered that the early 126 ones wetre reinforced  :oops:
jemima126
« Reply #6 on: December 30, 2009, 06:35:51 PM »
hi, i have a set, pm me and I will give you hubby's number for techy info!!
« Reply #7 on: December 31, 2009, 01:33:01 PM »
Also if you go for those rims you will need a new set of wheel bolts with a tapered face  [-/
ianhowe
« Reply #8 on: December 31, 2009, 02:12:14 PM »
Will one of these wheels still fit in the spare area ,on a 500 or will i use one of the 3.5" standard wheels?
