Author Topic: drill glass ??  (Read 2886 times)
bobblehead
  • monkeys on the move ..
    • my fiAT 126 PICK UP
drill glass ??
« on: December 28, 2009, 02:56:33 PM »
the door glass on my bis, keeps coming out the metal bit after its got up fully ..
could i drill a very small pilot hole through the metal and glass and put a screw in so the glass is fixed to the bottom runner and cant come out?
or will the glass smash ??
Re: drill glass ??
« Reply #1 on: December 28, 2009, 06:19:01 PM »
Once glass is toughened, it can't be drilled.
If the bottom runner keeps coming loose, have you tried bending the edges of the groove in to reduce the size of the slot for the glass, then forcing the glass back in? You would probably have to remove the whole lot from the door to give this a good shot.
Were the windows tight to open before this problem? this might indicate an underlying problem that need fixing too.
Michael
Re: drill glass ??
« Reply #2 on: December 28, 2009, 06:48:39 PM »
Check that you have the rubber strip installed in the window channel. Also fiat recommend that this rubber strip should be moistened with petrol before installing the glass.
More information here:
http://img686.imageshack.us/img686/7941/tn238.jpg
bobblehead
Re: drill glass ??
« Reply #3 on: December 28, 2009, 07:39:48 PM »
window glass was missing when i brought the car ..
got no rubber it was perished to buggery ,
where can i get some?? and will that just hold it??
will no more nails glue it?? you reckon ?
if i can get the correct rubber great ..
Re: drill glass ??
« Reply #4 on: December 28, 2009, 09:47:51 PM »
No nails wont bond to the glass.
The rubber isn't particularly fancy, It's only used as a flexible grip.
I would suggest cutting up a bicycle inner tube, wash it well using soapy water to get rid of the chalk.
using no nails or epoxy to glue the rubber to the runner,
if the rubber still isn't gripping the glass, bend the runner channel in so that it is a very snug fit.
Another option is that you could gaffa tape the glass to the runner, wait till I return home after new year then I can strip the runner from one of my spare doors and sell you it!
Michael
bobblehead
Re: drill glass ??
« Reply #5 on: December 28, 2009, 10:14:56 PM »
nice one i await. till your home
happy new year mate
Re: drill glass ??
« Reply #6 on: December 29, 2009, 08:31:50 AM »
What side door is it ? I have a part stripped door upin my shed , think it is drvers side. Did you get those headlamp screwws you were after ?
bobblehead
Re: drill glass ??
« Reply #7 on: December 29, 2009, 10:53:46 AM »
drivers door dude , and no screws either for the backs of the headlamps for adjustment ..
still looking for em
Re: drill glass ??
« Reply #8 on: December 29, 2009, 12:10:03 PM »
So re headlamp mounting : Have you got the nylon theaded inserts in place that take the adjustor bolts, the captive ball joint, The flat springs, the nightmare clips on the headlamp backing, the black plastic surround, the rubber boots over the main bulb etc ? I have located 4 adjustor bolts plus some of the other components.
Just braved the weather to get up to my shed and my part stripped door is passengers side but I also have a drivers door if Michael's parts are not OK  [-/
bobblehead
Re: drill glass ??
« Reply #9 on: December 29, 2009, 01:20:07 PM »
need all what you listed, thanks for braving the weather .
no need for new door though . thanks ..
Re: drill glass ??
« Reply #10 on: December 30, 2009, 12:12:11 PM »
Been back to look at the old motor in my garage. The bit I described as the captive ball joint is part of the front panel and the inserts that the 2 mounting bolts screw into look like they may be dificult to remove. Have you checked yours out up close ???
bobblehead
Re: drill glass ??
« Reply #11 on: December 30, 2009, 01:38:25 PM »
ahh just remember ive got a front end, i will go look see if any screws are there ..
not sure what you mean about captive balljoint etc ? if you got a cam could you take a pic?
all i need is some adjusting screws , and a window rubber for drivers window bottom glass holder ..
bobblehead
Re: drill glass ??
« Reply #12 on: January 21, 2010, 01:48:12 PM »
sorted, now, i gummed it up with gutter sealent. works a treat ..
wait till summer now and see if it melts and turns to mush, causing me a problem, but right now its fine ..
