Author Topic: fitting an oil cooler to a BIS  (Read 2951 times)
bardy
« on: December 17, 2009, 11:42:27 PM »
do you no where the best place would be nd how to fit an oil cooler to a BIS?
bardy
Re: fitting an oil cooler to a BIS
« Reply #1 on: December 18, 2009, 09:28:57 PM »
any body
any help is thankful
« Reply #2 on: December 18, 2009, 11:06:22 PM »
the problem with this bardy is that the bis has no oil filter so you cant fit an inline take off for the cooler - can i ask why you want to fit one- what are you doing with your bis to warrant an oil cooler?
bardy
« Reply #3 on: December 19, 2009, 12:24:00 PM »
well its to aid cooling realy  but i saw it on another thred that sum one put another front heater matric under the car to aid cooling i was thinking of doing that aswell but i guess al av to just do the heater matric idea
« Reply #4 on: December 19, 2009, 03:39:08 PM »
why not just fit an adjustable fan switch then it will kick in at whatever temp you wish it to? the oil cooler is can be fitted to an aircooled easily so i cannot see why a bis cannot have one, normally the cooler pipes exit from the oil pump housing on an aircooled engine have a look on the nanni site for an example and then get your thinking head on .
bardy
« Reply #5 on: December 19, 2009, 09:04:03 PM »
well i got a big thinking head wi what av dun to my car lol i will do tar bis13
« Reply #6 on: December 20, 2009, 09:09:31 AM »
bardy
« Reply #7 on: December 20, 2009, 12:01:25 PM »
well my dad bought some  day running lamps and am using them for my interior lights, but i want to make a   cold air feed nd stick a cone air filter on end nd i want to put another heater matrics in but underneith car to help cool engine, but were looking for a new heater matrics or sumthin we can use for one evan if its long and thin
« Reply #8 on: December 20, 2009, 06:11:58 PM »
Can't understand why you want to fit an oil cooler if the engine is bog standard ??? If it were a full race engine with big valve head, high compression pistons, race cam and big carb then it would be a good idea IMO [-/ but not for a standard engine.
Also there is not a problem with the cooling system if you take the bottom mounted thermostat out, or better still invest in a top mounted thermostat kit this keeps the water in the system at the correct working temperature while switching the cooling fan on earlier because of its top mounted position, Cio and I have this kit fitted and even flat out on the motorway for hours it has never overheated and sits between 1/2 & 3/4 on the temp gauge. fitting extra radiators and oil coolers seems to be alot of work, effort and cost, and really is not necessary for the standard engine ;)
Keep up the enthusiasm and hope to see your 126 on the road soon [-/
bardy
« Reply #9 on: December 20, 2009, 06:34:02 PM »
well its all good things for me so i can learn nd adapt things in the future its experiance nd tbh ad rather do it all now while i carnt drive than do it when i can drive cos al not do it then lol rember am 17 nd if i can learn to do things that can save the engine thens its good practise for me i think
« Reply #10 on: December 21, 2009, 03:48:40 PM »
Going off on a slight tangent here & a couple of thoughts. The modified air cooled cars tended to fit a larger sump to ease the effect on oil temperature which made me wonder how similar the A/C & Bis sumps are as the A/C sump you have the double skin with cooling air being directed underneath . Not applicable to the Bis I would think.
The big ally sumps are quite expensive but if you had a spare standard sump and knew a good fabricator / welder then an inexpensive modified sump could be possible , about 4 litre capacity seems about right.
Again not sure about the Bis but the A/C engine has an alluminium threaded plug near to the oil pump. On my "big" engine the oil pressure switch had been switched to that position and an oil pressure gauge sensor was fitted where the switch was originaly.
« Reply #11 on: December 22, 2009, 03:11:41 PM »
On the Bis the sump is made of cast alloy so dissipates the heat of the oil nicely.
