Author Topic: Standard Tuning a Bis?  (Read 3293 times)
« on: December 17, 2009, 08:03:24 PM »
This has proberbly been posted before, anyway here goes.  Since swapping my exhaust my performance has dropped, lost any power in the middle of the eccelarator pedal, have to put it hard down to get any responce!
Is there however some basic tunes that can be done?  Will swapping the air filter make any difference?  Can the carb have larger jets fitted?
Also does anyone know why I may have lost some power?
Re: Standard Tuning a Bis?
« Reply #1 on: December 23, 2009, 07:04:48 PM »
hello.....
Fifi
« Reply #2 on: December 23, 2009, 10:24:53 PM »
have you changed the outlet diameters of more clearly?
may be that the engine exhaust draws  clear air from the outside.
http://translate.google.com/translate?js=y&prev=_t&hl=pl&ie=UTF-8&layout=1&eotf=1&u=http%3A%2F%2F126p.no-ip.info%2Fdzial.php%3Fid%3D77205&sl=pl&tl=en
« Reply #3 on: December 24, 2009, 08:06:52 PM »
This is great but the translation is not so good, could you maybe re-write it?
Thanks :D
pumex
« Reply #4 on: December 25, 2009, 11:21:06 AM »
1. Remove the can with the air filter. Disassemble all of it so you can have in your hand only the top part - the one that is closing all of it from the top and is delivering the air to the engine. http://126p.no-ip.info/fotki/bis_dolot/100_2088.JPG
2. Take the angle grinder or other tool like that and cut off all of the bottom part of this pipe. This should look somewhat like this: http://126p.no-ip.info/fotki/bis_dolot/100_2089.JPG . Now the air will be taken not only from the one narrow side, but from all the width of the filter.
3. You can also direct the rubber pipe that is developing the air to the filter can catercorner downward toward the gearbox. Additionally if you have in this can a switch winter/summer you can take out from the silencer and the filter can leaving the hole open and set the closing plate vertically or lightly slanting right. If there will be small amount of air the engine will suck fresh air that it needs and if there will be too much air it will be gone by this hole.
All of this improved the performance of my engine - not anything amazing, but it helped.
Remember about changing the air filter regularly.
Designations of air filters made by different manufacturers:
- Sędziszów WA 50-120,
- Filtron AP 019,
- Champion u580/606,
- Kager 12-0124,
- Mmann-filter c2629,
- Magneti Marelli 150010037200.
If you like hardcore you can totally remove the air filter can, leaving only the hole to the silenter of additional sounds (?) on the pot. I was driving like that a few times and it really improve the performance of the engine, but you should use it only on short distance on asphalt because you cant allow the sand to get to the pot.
Fifi from http://126p.no-ip.info/
Hope it will help you :)
« Reply #5 on: December 27, 2009, 03:06:25 PM »
Great thanks!  Could you fit a third party air filter, say off a motorbike or such like?
« Last Edit: December 27, 2009, 03:38:51 PM by ciaoflyer »
K666STW
  • 704cc of pure fury.
« Reply #6 on: October 31, 2010, 05:36:36 PM »
This is bound to be worth and extra 10bhp then.  :D
« Reply #7 on: October 31, 2010, 10:38:48 PM »
Is this yours?  If so talk me through it!
K666STW
« Reply #8 on: November 01, 2010, 06:48:27 PM »
It is mine but it's a temp bodge. It's an inclosed induction filter on a rubber reducer onto the original tubings elbow. The reducer had to be cut to make one end much smaller to fit the original tubing, this left a gap that I've tried to get the oil breath to attach too.
It's only there because I've been a dumb ass and fitted my new fuel pump in such a way the original airbox won't fit back on properly. The filter itself is probably to big for the engine since it's a spare for my 2.0l Marea.
neil 126
« Reply #9 on: November 06, 2010, 05:57:08 PM »
I too am looking for a non standard air filter. Over the years and many house moves i have lost the lid to the air filter box.
I have a brand new air filter but have been unable to make use of it.
For he past couple of months i have been running the car with no filter which does seem to give better performance but i am wary of dirt getting into the carb and combustion chamber.
I would like to fit a K&N style cone filter to the air inlet, either direct to the top hat or to the rubber connector.
Has anyone doen this?
If so what make and model of filter have you used.
with the ai filter box removed there is a lot more space available to fit a larger filter giving better air flow.
learnt it the hard way
« Reply #10 on: November 06, 2010, 06:28:37 PM »
Go to the local motorcycle shop and buy a filter that will fit direct to the rubber tube...
http://www.diytrade.com/china/4/products/1905254/Dirt_bike_spare_parts_Air_Filter.html
« Reply #11 on: November 06, 2010, 07:21:42 PM »
Unless you are thinking of driving through a sand storm or through a plague of insects then I would not worry too much about air filters. I ran my Austin Healey Sprite for 101,000 miles with just open ram tubes on the twin carbs & no problems.
The engine can cope with the pollen in the air you just need to keep the large bits out  ;D
However with a downdraught carb  the last thing you want is not knowing what happened to the missing M6 nut  :oops:
Picture shows an auto jumble basic filter which was easily modified to fit the Weber  [-/
« Reply #12 on: November 06, 2010, 09:04:55 PM »
ive ran with just a mesh on mine for around three years maybe more and i havent had any problems..........yet.
