Author Topic: odd sized air vent??  (Read 2396 times)
Tomasz
« on: December 16, 2009, 05:21:23 PM »
As some of you know i am helping bobblehead with his pickup project.  Well its nearly done!  Have come across and odd problem though.  I cant find a vent to fit one side of the car.
Here is a picture of both sides, one with a vent fitted successfully (note diagonal position of screws) and the other where the screws and hole are square  which looks to be too big for the smaller type aircooled vents but will not fit bis vents.  The only ones i have not tried are my larger type aircooled vents but i assumed these are the same as bis vents.  I am aguessing this panel has been replaced at some point which is why it is not the same as the other side. Any ideas??
« Last Edit: December 17, 2009, 12:03:44 AM by ChrisRLewis »
Re: odd sized air vent??
« Reply #1 on: December 16, 2009, 05:28:28 PM »
now taking the vents off my bis and  welding up the holes - youre welcome to come cut out the vent metal and weld it into yours if you want tomasz...
« Reply #2 on: December 16, 2009, 06:37:55 PM »
I have so far seen the 126p with three different looking air vents that are factory spec. One is the standard that's on the majority of air cooleds, then there's the new looking vents from '88 onwards and then there's a third type for which i can't tell you for what year they used it on. The green 126 in the photo is an '87 model, which in my opinion is a cross between the old and the newer version.
jose
« Reply #3 on: December 16, 2009, 07:17:27 PM »
that is weird, is almost as if there was supposed to be a square vent on there...
126BIS 1990
jose
126BIS 1990
pumex
« Reply #5 on: December 16, 2009, 08:13:36 PM »
There where three types of this vents
old type produced till 84 which was small
the one that you have on your photo - in FL from 84 to 94
and small like on the picture that Jose posted - there were mounted from 1994 to 2000 in 126p el (elegant)
From what year this car is? Maybe you are right that this part was replaced.
Tomasz
« Reply #6 on: December 16, 2009, 08:20:52 PM »
Haha, i think it is the only type that i do not have!  My 126p is 1991 so that has the larger type.  The other are earlier uk aircooled's.  Thanks for all the help guys.  The panel must have been replaced at some point.
pumex
« Reply #7 on: December 16, 2009, 08:37:19 PM »
btw, are you from Poland? Cause Tomasz sounds like a polish name :)
« Reply #8 on: December 16, 2009, 09:07:15 PM »
most strange it might indicate this car has got history and has been given a good whack at some pointis there any indications that big amounts of panels have been changed on this side? i will have a look as i have some odd vents knocking about the only problem would mean they will be odd. have you considered knocking up some that will cover the different size holes and still look matched?
bobblehead
  • monkeys on the move ..
    • my fiAT 126 PICK UP
« Reply #9 on: December 16, 2009, 11:47:43 PM »
11 previous owners :) somethings gotta to have happened ...
might custom something or have old ? be quirky hehe .
thomasz is thinking of ideas and i am too ..
if you can find a vent mick would be great
