Author Topic: Lead additive  (Read 1777 times)
richk
Lead additive
« on: December 14, 2009, 10:44:43 PM »
Should I use Lead replacement liquid on my 600cc engine? It's still the original engine.
I do use it at the moment because I always did in my 1970's air cooled VW's and I still have plenty of it, but am I wasting my time?
Thanks guys.
Rich K
Re: Lead additive
« Reply #1 on: December 14, 2009, 11:28:11 PM »
I would personally stick with a lead additive. They are cheap enough and it's better to be on the safe side ;)
pumex
Re: Lead additive
« Reply #2 on: December 15, 2009, 06:18:43 PM »
Not using lead replacement can damage payload (I'm not sure if it is translated correctly) so you should use it, but nothing will happen if you forgot it sometimes :)
I dont know anything about italian engines, but if you have 126 from Poland, than you should use this replacement if your engine was produced before July 1992. If your engine number is higher than 6621475 than you don't need to use it.
But if you habe 600 cm3 than you definitely should use it :)
richk
Re: Lead additive
« Reply #3 on: December 16, 2009, 08:56:39 AM »
Ok. Cheers guys.
