Author Topic: Bis Exhaust Changed  (Read 2769 times)
Bis Exhaust Changed
« on: December 06, 2009, 04:13:11 PM »
Hey
Replaced my Bis exhaust today because it was blowing quite bad.  Got it off and sure enough two holes by one of the pipes, it also has a crack near the rear mounting bracket!  Anyway had a spare exhaust in good nick and it now purrs a treat :D
Just wondered before I chuck the old one can it be repaired or is it not worth it?
Re: Bis Exhaust Changed
« Reply #1 on: December 06, 2009, 05:02:31 PM »
it only needs welding you can patch it up no sweat.
bobblehead
  • monkeys on the move ..
    • my fiAT 126 PICK UP
« Reply #2 on: December 06, 2009, 07:13:54 PM »
i would just use soe liquid metal or jb weld, its like a putty thats hardens into a weld / steel .
welding a exhaust in my opinion is not a long term option, as they rust and rot from the inside out ? ..
so bodge it r cheap fix it until it gets unbearable then swop it out for a new one .
incidently ive got a new pipe for a bis you could have had collected for £50 ?  im in nottingham ? .. you didnt need it though . hehe :P
« Reply #3 on: December 06, 2009, 11:45:05 PM »
rich you cannot put that putty stuff on exhausts it just falls off after its burnt off dangerous fumes into your lungs . you might as use blu tac the weld will be fine the only problem with the bis exhaust is stress fractures caused by bolts or brackets coming loose. any exhaust will degrade from the inside the problem being moisture building up in the internals due to lack of use so the moral of the story is tighten up your nuts and make sure you use it often...
« Reply #4 on: December 07, 2009, 05:07:41 PM »
OK been to work and back today, engine ticks over much better and alot quieter!  Only thing is it seems to accelerate slower than it did before, is this normal or will the engine need retiming etc?
bobblehead
« Reply #5 on: December 07, 2009, 06:54:43 PM »
http://epoxyputty.com/thermosteel.htm
thermosteel doesnt shrink or give off harmful gases ?????
« Reply #6 on: December 07, 2009, 09:54:35 PM »
is this the begining of a jb weld debate? i am firmly in the "not worth the bother" corner as i have put this stuff to the test and its 5hite same for the plastic metal stuff it simply does not work, good old fashioned weld is mans stuff exhausts are not the place for some nancy boy arty farty putty lark, maybe you could knock some up and stick it on the school of satchi.... ;D
bobblehead
« Reply #7 on: December 07, 2009, 10:03:00 PM »
was just giving options to people who dont have the money or access to a welder .
thermosteel , like it or not is good for exhaust repairs .
jb weld not so, but still works ok..  ive used jb weld on my petrol tank on my monkeybike and so far 3 years later still no leaks or problems touch wood .
you can even get fake jb weld now from pound shops ...  worth a go at a quid of anybodys money .
anyway debate over i bow out ...
« Reply #8 on: December 08, 2009, 08:54:36 AM »
I think that plastic repair is good if you have no other choice (ie irreplacable part) or its a get you home (i had a plastic bleed plug break on my bmw once and used his to get me home)
But I must admit if i had the choice I would go for welding if that was how the part was intended.
again that said I repaired my uno tank some years back with it and it never leaked but a fuel tank is not subject to the heat, vibration and stress that a 126 bis exhaust is...
bobblehead
« Reply #9 on: December 08, 2009, 12:04:52 PM »
ive bowed out ...
wasnt talking about plastic repair on a exhaust though .. thermosteel i was
that saying at end of the day, if you can and you have the dosh, dont repair replace .
laters ..
im selling thermosteel tshirts to wrap round bis exhausts if anyones interested :P
laters hehe
« Reply #10 on: December 08, 2009, 04:18:05 PM »
do you have shares in the company too?  ;D ;D ;D
bobblehead
« Reply #11 on: December 08, 2009, 04:26:28 PM »
actually yes :)
with a stock of only a few panels off a bis .
any takers?  oh and a exhaust hehe (new no holes )
hey stuey did you go see thomasz ?
« Reply #12 on: December 08, 2009, 06:23:28 PM »
Thanks for those thoughts guys! :)
Back to my poor acceleration, it is fixed.  I had switched the Airbox to Winter setting and it did not like it, switched it back to Summer and it goes like a (slow) rocket! :D
