Author Topic: Leaking  (Read 1697 times)
jon.hunt
Leaking
« on: December 04, 2009, 03:32:12 PM »
Hi All,
         My Air cooler 126 Leaks water and it runs along under the Dashroll to one end or the other then drips on to the NEW Floor,  Cannot do with the floor rusting again, is there a common Leak!! Etc:-  I've tried resealing the windscreen but it still does it when Parked.
                                            Jon.
Eklipze3k
Re: Leaking
« Reply #1 on: December 04, 2009, 03:36:42 PM »
Mine leaks water through my driver's side door window sometimes in heavy rain or when I'm hosing the cair, but it usually only gets the seat wet.
Re: Leaking
« Reply #2 on: December 04, 2009, 03:46:41 PM »
might be worth taking the screen out and getting it put back by some professionals with a new rubber, I had probs with mine and did this, there was a small hole under the rubber I welded as well...
Re: Leaking
« Reply #3 on: December 04, 2009, 07:14:31 PM »
the leaks are normally down to the rubber ageing and so it shrinks a little and lets water through it can enter through either under the seal and the bodywork or via the windscreen and past the rubber on the inside where the glass sits either way its a pain.
