Author Topic: ALTERNATOR  (Read 1713 times)
puck304
ALTERNATOR
« on: November 27, 2009, 01:17:18 AM »
 :cry: My alternator's died on my aircooled, put a new battery on a month ago, and now it's dead and won't run for long even after a jump start! Has anyone got one for an aircooled? Or know where to get the bushes for on, I been told Lucas have gone under.... :cry:
prkahrvat
  • PEGLATRON
Re: ALTERNATOR
« Reply #1 on: November 27, 2009, 11:32:31 AM »
Maybe its not whole alternator, it could be regler or diodes. If your light of battery on cockpit start to light when you push throttle, and bright even more when you push more throttle, it could be diodes, but if light is shutting down when push throttle, it could be regler. It can be easier to measure with unimer (i don't know how you call that thing which is measuring voltage), start engine, put unimers + (red) on battery +, and unimers - (black) on battery -. regularly voltage should be 13.2 - 13.6 (somebody correct me if i'm wrong). If you push throttle, voltage should be maximum 14.4, if it goes over 14.4, (let's say 16), regler is dead, and if voltage is 12 -12.3 volts your alternator is not filling at all, it could be stator, rotor or more than one diode, but if voltage is from 13.6 -14.4 and red light on cockpit is blinking, its only one diode dead. It's not extremely huge problem, you can drive your car but battery will be dead after few days, or weeks if you charge it whole time (and its not good for battery). Also you can start you car by pushing it, and it is not healthy for him. I think that prices of parts are about: regler 10-12€, diodes 40-50€ and whole alternator 150-160€.(correct me if i'm wrong). so it would be better to figure out which part is dead, so you don't have to buy whole new alternator.
Sorry for bad english!
Re: ALTERNATOR
« Reply #2 on: November 27, 2009, 06:25:43 PM »
take it to a local specialist and have it refurbished it normally costs around £50.
