Author Topic: Foolishly lost part for Abarth Rocker cover (Gucci)  (Read 3052 times)
« on: November 26, 2009, 09:58:37 AM »
After deciding to tart up my engine a little more to celebrate it passing another MOT, I recently fitted one of those silly 'Abarth' rocker covers. Stupidly I failed to tighten the brass breather/pressure release pipe that screws into the neck. Needless to say it dropped off somewhere on my 9 mile drive late last night. I only noticed, when i was stopped in traffic, the engine seemed to be making a very 'blowy' noise. once stopped, i checked and found that it was missing this bit.
Does anyone know where I can buy a replacement for this part, which is basically just a special shaped hollow bolt?
It's the part circled below
Re: Foolishly lost part for Abarth Rocker cover (Gucci)
« Reply #1 on: November 26, 2009, 02:53:03 PM »
take the rocker cover to B&Q. it's probably a standard plumbing thread, you should find something to  do the job.
Michael
« Last Edit: November 27, 2009, 12:44:31 PM by Dom »
« Reply #4 on: November 27, 2009, 01:45:50 PM »
They look ok, but the one with the 1/4" thread will be far too small.
The advantage of taking the rocker cover to B&Q is the you can screw it in and check it fits.
I'm not sure if the hole is used as pressure relief as I've never seen one up close. You could buy an open one, if it leaks too much oil you could bolt on an end cap and drill a whole to the right size. Are you sticking a breather pipe on the end of it?
« Reply #5 on: November 27, 2009, 02:08:57 PM »
Not too sure. I was thinking of fitting a small catch tank (or coke can) as with the old rocker cover, with the oil cap off, it used to let quite a bit of oil out (possibly a piston ring problem!). However it only seem to let air out as if I hold my hand over the hole for a few minutes, it stays clean.
I think i'll try the B&Q idea, at least to work out the exact thread required if nothing else.
« Reply #6 on: November 27, 2009, 06:51:11 PM »
dom you are not alone i nearly lost this piece too however mine was in the garage as i had taken it off to measure up some pipe and mislaid it .... i hope you are successfull in your search if no luck in b&q try any local specialist hose suppliers you never know!
« Reply #7 on: November 29, 2009, 06:30:22 PM »
If that fails look for your local Pirtek (i think thats how you spell it)
They'' make anything even custom bits.
« Reply #8 on: November 30, 2009, 03:18:20 PM »
Cheers for all the reply's guys.
I've still not managed to get down to any plumbing shop. I wont be back in the car until next week, so wont get to check the thread. Would anyone happen to know what size and thread the pipe is?
« Reply #9 on: December 03, 2009, 04:58:03 PM »
Hi Dom , had any luck with that part yet ? I found a couple of similar items up in my loft but the thread size is the all important thing. Are you able to get an idea of size ?
« Reply #10 on: December 08, 2009, 01:55:20 PM »
Still not found it. I've been on holiday for a week, so will get the hunt back on this evening as i haven't driven the car for a while. I'll take the cover off and try and work out the thread.
