Author Topic: BIS Cooling - electric pump  (Read 1800 times)
fly
« on: November 24, 2009, 10:02:32 PM »
Hi guys,
I was reading through one of the other threads - about 5 below as I write - anyway, has anybody else done this on their BIS, ie ditch the the mechanical pump in favour of an electric item; does anybody know what sort of pump to use, an auxiliary or charge cooler off something else, or something totally different? Any ideas or knowledge anybody can impart would be appreciated - or do you think that it would be a fruitless excerise trying to use an electric pump and I should leave well alone?
« Last Edit: November 25, 2009, 01:08:21 PM by fly »
Re: BIS Cooling - electric pump
« Reply #1 on: November 29, 2009, 10:42:54 PM »
In my opinion a complete waste of money, if you intend keeping the car just remove the thermostat or consider investing in the top mounting thermostat kit available from Ricambio on Ebay, I fitted the conversion 3 years ago and never had a problem with overheating [-/
fly
« Reply #2 on: November 30, 2009, 12:48:49 PM »
Think I'd reached that conclusion - took the thermostat out at the weekend, also going to fit a copper head gasket, Ricambio have some on ebay.
