Author Topic: rooflining for a BIS  (Read 2750 times)
chrisrhodesinlbz
« on: November 23, 2009, 09:16:20 PM »
My 126 BIS did not have a rooflining when I bought it, I have lived without one for such a long time now and just got used to it....but does anyone know where I could get a new one, or how to improvise a substitute?
I can't even remember what the original is meant to look like or how it fits, but am sure it would make 'Bubble' quieter and more snug.
As ever, any hints and advice gratefully received !
Re: rooflining for a BIS
« Reply #1 on: November 23, 2009, 10:35:11 PM »
« Reply #2 on: November 23, 2009, 10:50:38 PM »
There is one currently being sold in Ebay, "Cielo Sottotetto FIAT 126 Bis FSM Roof panel insert". Web address: http://cgi.ebay.co.uk/Cielo-Sottotetto-FIAT-126-Bis-FSM-Roof-panel-insert_W0QQitemZ220259762018QQcmdZViewItemQQptZRicambi_automobili?hash=item3348813f62
« Reply #3 on: November 23, 2009, 10:52:05 PM »
AXEL GERSTL is quite good. I have acquired a couple of spares from them in the past. So relatively safe.
Alex
« Reply #4 on: November 24, 2009, 09:44:15 AM »
my roof lining was ripped when i bought my Fiat, so i removed it, stripped it back to the hardboard used the old one as a stencil then got  anew one routered out, and the wife bought some bright red material for the new lining,
the material only cost a tenner,
you could get a new hardboard panel routered for about 20 quid, all you'd need is the stencil.
i think you could get it all done for well under 50 quid,
if you need any further advice then just ask, as i found it a really simple job and saved loads of money compared to getting one from abroad.
hope this helps
« Reply #5 on: November 28, 2009, 09:00:00 PM »
Hello.My rooflining could be improved and have looked at the original replacements. I am interested in your approach and perhaps I can replace the thing myself. Was the rooflining difficult to remove? The rear bit of the rooflining/hardboard is kept in place by what looks like plastic grommets/screws. Was your original rooflining glued to the roof metal? Did you then glue your new rooflining in place?
Alex
« Reply #6 on: November 30, 2009, 01:40:10 PM »
yeah the roof is held in place with those plastic clips, once they're in you cant get them out without braking them. this was not a problem as i double layered that part with material then it fitted snugly in place.
it was not glued to the ceiling, and is relatively easy to get in and out, i found it easy if smeone guided it from the back.
it needs to go in in a smile postion and once its guided into place by the front windscreen you just push it up, slide it back and its all done.
for extra insulation i used the cheap foam you put under laminate flooring, one word of note would be be careful as to how tight you stick the fabric down, because of the obvious stresses you're placing it under.
hope this helps
« Reply #7 on: November 30, 2009, 08:17:30 PM »
I think a good idea would be if you could measure up the roof template and post the dimentions on here then others could make their own.
Alex
« Reply #8 on: December 01, 2009, 09:36:46 AM »
the only problem that would involve is the curved edges at the front and back, i traced the old one onto a sheet of hardboard and cut it on a bandsaw.
plus everything is glued in place, if anyone has a broken roof and lives in essex i dont mind picking one up and creating a technical sheet on the dimensions and radius of the panel.
sorry i cant help any more
chrisrhodesinlbz
« Reply #9 on: December 28, 2009, 07:20:56 PM »
Fabulous! Thanks for all your help, my car, Bubble, will have a new rooflining, on it's way, and will be nicely trimmed, many thanks to Forum members!
Alex
« Reply #10 on: January 13, 2010, 12:16:51 PM »
did you buy it off Axel Gerst then?
