Author Topic: door hanging, any advice?  (Read 2056 times)
« on: November 21, 2009, 02:50:21 PM »
Hi all,
Just bolted on my replacement drivers door and its sagging towards the rear of the door. I'm sure a bit of trial and error will get bolted in fine, but I was wondering if anyone had done this before and knew a good way to set it right.
Michael
Re: door hanging, any advice?
« Reply #1 on: November 21, 2009, 10:28:14 PM »
like you say trial and error is it a new door or from a donor car as it could be suffering from effects of age or that at somepoint too much leaning on the open door has bent the hinge , you could use shims behind the lower hinge to raise it if nothing else works.
« Reply #2 on: November 22, 2009, 11:49:40 AM »
Yeah, it's off a donor car, I'll try  re-fitting the old door today, if it sags too then I know I'm fitting it wrong!
Failing that I'll have to manipulate the hinges in some way.
jose
« Reply #3 on: December 16, 2009, 09:05:57 PM »
i had this problem, door was too low at the catch and was clunking badly just to get it up to level with the 1/4 panel. adjustment on the hinge was maxd out too.  as stated above it's probably a result of too much leaning on the door which can bend the hinges over time.  dont be afraid to get under the door and give it all you've got to wrench it upwards! it'l creak and sound bad but very unlikely you can do any damage, the creaking is just the hinges bending back to normal!
126BIS 1990
« Reply #4 on: December 17, 2009, 01:04:26 PM »
as much as some one is bound to say its a bad idea I have with success used a trolley jack under a door before to correct saggyness...
Eklipze3k
« Reply #5 on: December 17, 2009, 01:17:10 PM »
I was so tempted to make a saggy old man joke but I think I'll leave it ;)
