Author Topic: Weak/dead battery  (Read 2876 times)
Weak/dead battery
« on: November 18, 2009, 11:32:13 PM »
I try to drive my 126 on weekends but only in dry weather. It would turn slowly but on the whole it would start on the third try. The weekend that just past was a washout but the Sunday afternoon, it sort of brightened up. I decided to drive it but unfortunately, found that the battery was almost dead. The lights on the instrument panel was very weak, so the engine did not turn. I had to use my other car to jump start it. It took a couple of minutes of charging (revving the other car slightly) before the battery was strong enough to turn the engine. It started after that. I wonder if the battery needs replacing or the battery got drained due to some faulty wiring somewhere. Or is this normal for the 126? I have one of those old CD radios with a pull-out panel face. Once the panel face is removed there is a blinking red light on the facia. Could this be the cause? I have been told that the 126 hate being idle and therefore needs to be driven. I am hoping for dry weather this coming weekend so that I can go for a drive but I am a bit concerned that the battery may be flat again. Any views?
Re: Weak/dead battery
« Reply #1 on: November 19, 2009, 12:20:10 AM »
try fitting a quick release battery connector one it stops any drainage from the battery and two it also deters thieves.
« Reply #2 on: November 19, 2009, 06:54:55 AM »
Check the battery connections & earth points then the fan belt tension. Often with an alternator if the belt is slightly slack It will put out enough juice to put out the ignition light & run the engine but not much more. Lights & wipers are a big drain And battery efficiency will be down in the colder weather. A normal motor factor can test the battery also with their gizmo.  [-/
« Reply #3 on: November 19, 2009, 06:34:55 PM »
Many thanks for your thoughts. I will install one of those quick release battery connector as well as check the belt tension on the alternator. Do you know where I can get a quick battery release connector? Halfords? Ripspeed used to sell it but it went out of business some years ago.
Is there a way of testing the integrity of the battery? You mentioned a gizmo?
defender90
« Reply #4 on: November 20, 2009, 09:51:35 PM »
  In all probability it probably is a tired battery but i agree with rusty you must check your battery terminals and alternator connections and belt tension first. If all good put a meter across your battery whilst on a high tick over, a healthy charging system with good alternator and belt tension should read 13.5 - 14 volts. A battery isolator isn't needed on a 126 as they don't suffer from excesive standing disharge as they don't have any electrical gizmos, even the CD red light you talk about is only a LED using virtualy zero power.
  No cars realy like being stood and an occasional 5 minuit run on a Sunday will not put back into the battery what you have taken out and so even a good battery and charge system will fail eventually on any car but 126's usually stand up better than most. I can go to mine after 3 months pull the choke with NO throttle and it will fire up fine.
  Any auto electrical store should test your battery for nothing but ask them to show you how they are testing it so they don't just fob you off with a new battery regardless. To test a battery properly they should use a drop tester, if your caps are removeable they will take them off first and you will be able to see any dodgy cells bubbling up.
Kevan
Radcliffe
Gt.Manchester
Citroen BX TDG (soon to go)
Citroen BX TZD
Land Rover 110 Station Wagon
« Reply #5 on: November 21, 2009, 04:09:57 PM »
Many thanks for your all your advices. Defender90 you may be correct. I usually have no problems starting the car on weekends only (subject ot weather conditions, so it could be idle for two weeks). I am happy to say, that the car started no problems this afternoon. I think what happened last weekend was a fluke. Defender90- I take your point, I will make sure I drive more than 5 minutes weather permitting! Having said that, I will still get the battery and charging system checked as I am also unsure how old the battery is since I bought the car. It is also perhaps still worth investing in a battery isolator as occassionally I get a secondment and is away for a couple of weeks and I know my other half will not drive it. As Bis13 states, it also doubles up as a deterrence. I will also do Rusty's advices. I will ask Halfords in the coming weeks whether they sell a battery isolator, check the battery and charging system. and others. I will revert if the problem arises again.
Many thanks to all of you!!
Derek
« Reply #6 on: November 21, 2009, 04:55:30 PM »
Another thought is an automatic trickle charger to keep the battery at optimum charge.  I've used them on a motorbike & a Westfield as I didn't use them much in the winter.
« Reply #7 on: November 21, 2009, 05:40:12 PM »
There are loads on eBay well below £10 including postage  [-/
« Reply #8 on: November 21, 2009, 06:49:59 PM »
Do I need to disconnect the battery or remove the battery from the car to trickle charge it? How long do I need to trickle charge it and also frequency? I plan to use my 126 sparingly in the winter.
« Reply #9 on: November 21, 2009, 10:34:26 PM »
just a thought here but do you put your foot on the clutch pedal when you start the car? try doing that as the  flywheel turns far easier and spins the engine faster on starting.
« Reply #10 on: November 22, 2009, 08:23:20 AM »
Come to think of it, I must admit, I do occassionally forget to press the clutch. It would turn very slowly and start for a second but as soon I release the ignition, it dies. This would happen on several attempts and then realise that I forgot to press the clutch or when cold forget to switch on the choke. Sometimes I forget to do both simultanously when cold but I am getting used to the car's idiosyncrasies.
The battery isolator is a good idea. The car of a friend of mine got stolen some years ago and was never recovered. It was a fully restored 70's VW beetle which he just got back from the restorers. All it had was a steering lock gizmo. I think the battery isolator is a much better deterrent.  Many thanks.
Derek
« Reply #11 on: November 22, 2009, 03:45:01 PM »
Trickle chargers come with crocodile clips for the battery. The one I had also included with simple push connectors, you bolt the wires off the connector onto the battery teminals, these then stayed on the battery terminals. You then plug this into the connector on the wire from the charger. On a good trickle charger it can stay connected to the mains all the time & will cut in when needed & will not overcharge a battery, I don't know if this is the case on the under £10 trickle chargers from ebay. I bought a good one for about £40, though that was 10 years ago so they should be cheaper now. They're very good idea if you don't use the car frequently & keep the car in a garage with mains.
« Reply #12 on: December 14, 2009, 10:14:04 PM »
I just installed a battery isolator on my BIS. It works a treat. The battery feels stronger when starting. It also doubles up as a sort of immobiliser.
I noticed that when I switch on the rear heated window, it consumes lot of electricity. It slows down the signalling i.e the green directional indicators on the dash weakens, although, it does not affect the running of the car. Maybe I am paranoid but I think the battery is old and not that strong anymore. The battery isolator appear to work though.
