Author Topic: Engine Won't Fire  (Read 2100 times)
Alex
Engine Won't Fire
« on: November 09, 2009, 11:25:00 AM »
after chaging the Carb on the engine, for some reason it wont fire, and subsequently i end up with a misfire/blowback.
i'm really looking for some advice as to what this could be, both the sparks fire and are at the correct height.
is there a possibility the timing could be out? i'm not sure how it could be as i have not moved it since the carb came off!
if anyone has had the same problem i would really appreciate some advice as to what it could potentially be.
Alex
richk
Re: Engine Won't Fire
« Reply #1 on: November 09, 2009, 04:40:54 PM »
Hi Alex.
You say you've changed the carb but did you strip it all out and clean it thoroughly before fitting? There are a lot of jets and airways in there! If you take a plug out and put your thumb over the hole (while a helper pulls the starter) do you get thumb of petrol?
Rich K.
« Reply #2 on: November 09, 2009, 06:23:47 PM »
If you didn't touch the timing or ignition then maybe there isn't enough petrol in the carb. Try squirting a syringe of petrol into the carb when cranking and if it ticks over and runs until it has burned the petrol away then the ignition is fine. If nothing happens then there's something with the ignition or maybe there's a leak (did you change the carb. seal?)
Alex
« Reply #3 on: November 12, 2009, 10:01:45 AM »
HI,
yeah i thoroughly cleaned the carb and when i checked the plugs they were slightly wet as they should be. i'm really in a tight spot now, i'm racking my brains to think what it could be, i'm going to take the carb out again and strip it down, and will also do the syringe trick.
but if these are ruled out can anyone think what else could be the problem? the car was running fine then it the float got a hole in it, i changed that and now its not firing!!
any advice would be really appreciated
cheers
« Reply #4 on: November 12, 2009, 10:42:21 AM »
Take one lead off a spark plug, put a plug onto it and rest it against the engine, get someone to crank it and see it there is a spark.
« Reply #5 on: November 12, 2009, 10:57:36 AM »
take the distributor cap off and with the ignition on get someone to turn the engine over while you check the distributor points you should see the points arcing slightly when the engine is spinning.
Sounds like an ignition problem if the plugs keep getting wet.
« Reply #6 on: November 12, 2009, 01:08:22 PM »
Just a thought but you are not running a non wasted spark set up & got plug leads the wrong way by any chance  ;D
« Reply #7 on: November 12, 2009, 05:09:41 PM »
When you changed the float did you check and adjust the float level? I don't know what sort of carb or engine you have but to the best of my knowledge it should be 7mm (incl. gasket width and when the carb is held vertically).
