Author Topic: Fitting Towbar?  (Read 1772 times)
Fitting Towbar?
« on: November 08, 2009, 05:38:34 PM »
Fitted Towbar to Bis, looks good will post some pics soon!  However, had to undo the pivot bolt on the suspension to fit the bar to.  I have looked in the manual and it says it needs to be tightened to 7.8danm but what is this in foot pounds?
I have done it up as tight as I can by hand and it is also a nylock nut, is there any chance it could come off and if so what would happen?
Just thought I would ask b4 I go racing round the country side! :)
Re: Fitting Towbar?
« Reply #1 on: November 08, 2009, 08:08:33 PM »
i know 5lb ft equals 7 nm whats the danm bit? doh!!!
Re: Fitting Towbar?
« Reply #2 on: November 08, 2009, 08:27:53 PM »
Found This.
8 daNm = 80 Nm
80 Nm x 1 ft-lbf/1.355818 Nm = 59 ft-lbf
Re: Fitting Towbar?
« Reply #3 on: November 10, 2009, 08:24:21 PM »
Thanks guys, you were about spot on Pete Haynes manual for aircooled states 58 Foot pounds!  Anyway got another problem now :(
When pulling off in first gear the engine wobbles so much that it hits the towbar with some loud bangs!  Now my local Mech says that the gearbox mounts and the engine mounts need replacing to rectify the problem, He looked at the gearbox mounts and they have slipped out to the left!  Do you guys think that this is the problem?
Thanks in advance!
