Author Topic: Classic Car Weekly - information request  (Read 2982 times)
« on: November 06, 2009, 06:53:25 PM »
I have received a request from Classic Car Weekly who are intending to write an article on a Fiat 126 Buyers Guide.  The information that they require is what to look for when buying a 126? rust areas, mechanical problems, spares availability.. etc
If anyone is up to writing an article? (however short or long) please send to [email protected] I will then forward all articles to the Editor of Classic Car Weekly.
Re: Classic Car Weekly - information request
« Reply #1 on: November 06, 2009, 08:19:20 PM »
Hi Chris , I guess that would be an update on the buyer's guide they published in CC Weekly December 11th 2002 that I have a copy of here. Article by Paul Jones with "expert" opinion by Barry Gilleland ???? 126 registrar for the Motor Club GB. The expert bit I like is that in the history section it says that the exhaust was changed in 1982& improved fuel consumption by 12%  :oops:
In the Verdict section it says that " The water-cooled Bis has come in for a lot of criticism but they can be made reliable and plenty of owners swear by them"
I think I can name a few guys who swear at them  ;)
If you have not seen this article I can lend it to you if you PM an address. It is interesting with a hint of amusement.
On a silly note the the Buyer's guide should start with " Prices are rising , credit is hard to get & the Banks ain't lending"
On a more serious note, from my point of view , having been involved with 126s for many a long year plus the odd 500. Since the 2002 article the 126 in all it's forms has finaly arrived in so many ways  [-/
« Reply #2 on: November 09, 2009, 11:25:22 AM »
Hello, I am sure there is a wealth of experience in the club. I have a checklist of what to look for when buying a 126. I have been looking for one for some time but recently found a good example BUT I had to pay a premium for it. For what its worth, here was my checklist (not in any particular order). Everyone, please feel free to add bits to it. I am also not a mechanic. My list included my experience with a Fiat 600D which I previously owned.
It is essential important that the car has a full service history, documentation, MOTs, road tax and repair receipts. This will prove the authenticity of the mileage. It is also a reflection re the care given to it by its previous owners.
Engine
Look for any oil leaks, water leaks, white gunk under the oil cap. History of overheating. This is also a problem in the aircooled engines. Has the engines been replaced? Check whether the cooling fan works by letting the car run on idle see if it switches on. Hard starting. Lazy starter motor. When was the car last serviced. Check the engine compression. You can do this by putting it in first gear and trying to push it. If its easy, there's poor compression.
Gearbox
The 126 BIS gearshift is not as notchy as the previous models (syncromeshed), and it does not make a grinding noise on first gear. Make sure the gear box is good. The gearshift does not snap back into neutral on the lower gears on deceleration.
Bodywork
Inspect the underbody and mechanical components. Check the hollow spaces/parts in the underbody for rust particularly around the plugs (are supposed to sealed). Badly repaired damage or rust repairs. Uneven paint work. Exterior surface rust and holes. Also look at the bodywork under the battery. Rust in the spare tire area. Check under the carpets for rust. Check the interior doors for surface rust. Rust under the front and rear windshield particularly the front windshield. Check under rear hatch doors (126 BIS) for surface rust particularly around the drain holes. Rust around the front bonnet seal grommet holes. Give the door sills a good squeeze, especially have a good look behind the door-sill lower seam, and the section of floor just behind the front wheel arches. Rear corners of the seat runners, and inside the front wheel arches behind the thick plate that holds the upper arm. Make sure the seats run on its rails.
Electrics
Make sure all the buttons work on the dash although they're not too expensive to replace. Check for loose headlights and poor headlight reflectors. Casing may have rust in it. Also check that all electrics work.
Suspension
Enquire when the king pins were last greased/changed. I've heard they can be a problem. Lift springs should still be an inverted u-shape and not falling to pieces. Uneven tire wear. Should have correct camber. It should not swerve to left or right when breaking. Check steering knuckles and suspension ball joints boots and the bellows protecting the sterring linkage rods are in good condition.
Interior
Should be a clean interior. No broken or missing interior bits. Cracked or badly scratched plastic storage tray.
Please accept my apologies for the war and peace. I am probably just too meticulous.
Cheers - Amateb8
« Last Edit: November 09, 2009, 12:55:02 PM by Amateb8 »
« Reply #3 on: November 09, 2009, 01:38:07 PM »
 [-/ Nice correction on that spelling mistake "to meticulous"  </4 but we have all been there.
 :oops:
That is quite a list you have there & it is a bit like a letter to Father Christmas. So ab fab if all of those things check out & you may have a dream car but when people have asked me over the years to advise them on the purchase of a 2nd hand car I have always said that if you get what you paid for you are doing OK . Expect problems & if they do not happen see it as a bonus. Full service history with receipts can be a big ask especialy with cars that are imported. A bit of recent history is useful but other than that compare the meercat & try and keep a level head.  ;)
« Reply #4 on: November 09, 2009, 06:20:55 PM »
Hello! I have been looking for a mint Fiat 126 BIS (UK Spec) for a very long time, this  meant full documentation (incl fully stamped service booklet and owner's handbook) etc. as I mentioned and I was prepared to pay a premium for it. Believe it or not I found one with low mileage and full service history with its service book all stamped up to 2009. You are absolutely correct, in my search for a mint 126, having a full service history is quite rare but there are a few examples out there. For example, there is a 126 BIS (white) minter with low mileage currently advertised in Car and Classic with full service etc from new. I did the write up in response to Chris' request for information re what to look for in buying a 126. Feel free to top and tail the write-up as you see fit.
« Reply #5 on: November 12, 2009, 12:33:15 PM »
 Looks like it will be in next week`s issue. Coming out on Thursday. Looking forward to it :)
 Classic Car Weekly quote-"Less fancied than a 500 but equally deserving!"
« Reply #6 on: November 12, 2009, 03:45:28 PM »
Will get a copy!
prkahrvat
  • PEGLATRON
« Reply #7 on: November 12, 2009, 07:55:40 PM »
where can i buy copy?
Sorry for bad english!
« Reply #8 on: November 12, 2009, 10:06:58 PM »
I am definitely going to buy a copy but I have not seen this magazine at WHS Smiths.
« Reply #9 on: November 13, 2009, 11:28:24 AM »
 I`m sure WHS Smith have it, as I got it there before. It comes out every week in a newspaper form.
« Reply #10 on: November 13, 2009, 02:45:51 PM »
Whatever 126 you buy, and whatever the condition, you'll get your hands dirty fairly soon should be the advice  :oops:
« Reply #11 on: November 13, 2009, 06:17:06 PM »
I will have a look again. I was looking for a glossy magazine like Practical Classics.
Many thanks!
« Reply #12 on: November 15, 2009, 12:30:46 AM »
I did not find the newspaper, so I checked Classic Car Weekly's website to see what articles were featured in the latest issue i.e. 12/11/2009. There appears to be no mention of a 126. Perhaps it will be featured in next week's issue scheduled for the 19th Nov.
« Reply #13 on: November 16, 2009, 04:13:44 PM »
I found it. The 126 article will be published in the next issue coming out 19 Nov 2009.
