Author Topic: 126 & 500 Speedo cable  (Read 1572 times)
jon.hunt
« on: November 05, 2009, 03:23:12 PM »
Hi All,
        I've been having trouble with my Speedo and now its stopped, The fault is the Cable Inner has Snapped about Half inch from the End in the Gearbox Drive!!!!!  I cannot get the cable bit out so I'm having to replace the speedo drive bit in the Gearbox.  The moral to this Story is Check your speedo inner cable by taking it off the speedo, pulling it out and check the far end, if its Dodgy by a new inner cable and just push it back in,  Or you'll be like me with a BIG JOB underneath the car.  What could have been a 5 min Job, is now a Big Job.
                All the Best             Jon.
Re: 126 & 500 Speedo cable
« Reply #1 on: November 06, 2009, 11:56:19 AM »
I had this before, it was a nuisance!
I ended up unbolting the speedo drive unit and prizing it off the gearbox, once it was on the bench it was quite easy to prize  the broken end out with a pair of needle nose pliers
Michael
