Author Topic: Air cooled oil leak  (Read 2228 times)
bazzerbeeza
Air cooled oil leak
« on: November 05, 2009, 02:57:06 PM »
I have quite a serious oil leak which seems to be coming from the rear of the pulley that contains the oil filter. As a long shot I replaced the oil filter seal but that made no difference. I guess the problem could lie in the timing cover gasket or is there some kind of oil seal around the shaft within the timing cover itself?
Assuming the solution involves removing the cover, how do I undo the 32mm nut? I have put it in gear and chocked the wheels but still can't get enough purchase on it to get it to undo.
There was Duckhams 20/50 in before but, seeing some of the posts, I have refilled with Millers 1/40.
All help welcome.
Re: Air cooled oil leak
« Reply #1 on: November 05, 2009, 03:24:38 PM »
Could be Valve stem seals, they go hard and brittle. It's a common fault.
« Reply #2 on: November 05, 2009, 03:55:47 PM »
There is a lip seal that the rear of the pulley runs in. Only about £4 but if it has gone it will get messy as the pulley will act as a flinger and throw oil all around. Leaks from other seals or gaskets on the engine generaly just dribble oil around. The torque rating of 108 ft/lbs is by far the highest on the engine & has caused many a problem. I have seen a few reports where people have jammed the crankshaft with a piece of wood inside the engine and ended up punching a hole in the side of the ally crankcase when they tried to undo that nut. You do need to get a socket on it with a decent bar plus if you support the engine it is easy to remove the rear engine support panel & get good access. A Haynes manual is a good item to have , nearly always a couple on eBay & even the the early 1973 - 77 one covers most of what you need to know , Good luck  [-/
« Reply #3 on: November 05, 2009, 07:47:07 PM »
Mine used to spray all over the area behind the pully, it turned-out to be the bacolite bit between the fuel pump and engine had a crack in it.
I somehow doubt the cover gasket, but you'll need a mighty big socket to get the pulley off. :oops:
bazzerbeeza
« Reply #4 on: November 06, 2009, 07:14:32 PM »
Thank you for the advice, I am going with Rusty's Uncle's solution. I have ordered the bits and even managed to get the pulley off by borrowing a friends compressor with a hand gun on it that luckily has 1/2" suitable for a 32mm socket. I'll be back if this doesn't fix it, meanwhile thanks again.
« Reply #5 on: November 07, 2009, 12:02:36 AM »
There is a torque setting for the big bolt when you put it back on, but I guess if it's tight and has the locking ring in place it wont matter too much.
If it's your first time at it torque settings for all the bolts would be useful as it's a aluminium block, and over tightening can muck the threads up. [-/
« Reply #6 on: November 07, 2009, 12:00:47 PM »
the pulley connected to the crankshaft is a bit of a bitch to loosen i did use two rods to lock it up before i undid it in situ i posted it somewhere but dont know where! i shall think if you get an airtool on there then that will do the job also in last months practical classic there was a tip which might help , get some polyester cord and sheep bend it onto some thicker nylon rope then wrap it around the pulley where the belt normal sits pull till its tight then anchor the rope to somewhere on the engine ,as you untighten the pulley the slack will be taken away as the pulley moves around until it cannot move no more then you can undo the bolt/nut easily. sounds good have a try!
