Author Topic: Air/Water cooled differences  (Read 2435 times)
Simon
« on: October 24, 2009, 06:47:52 PM »
Folks,
Apart from the slight increase in engine capacity and move to water cooling, what are the other differences between the air/water cooled car.
Ie Are the body panels etc interchangeable?
ATB
Simon
Re: Air/Water cooled differences
« Reply #1 on: October 24, 2009, 09:45:11 PM »
I haven't worked on a BIS before but there are a few differnces:
I think the panels are the same because i fitted BIS fenders on my aircooled (though there were a few mm differences here and there but that's probably because it's an aftermarket product.) The panel under the winscreen on the BIS has air vents, and the BIS has a tailgate.
The engine i think is totally different, maybe the carb and ignition is the same.
The transmission is the same, i think the only difference is the final gear ratio.
The bis has rack and pinion steering and different sized wheels.
The BIS has more added extras than the earlier aircooled versions, but post '88 or '90 aircooled 126's got them as well (rear windows can be opened, different dashboard, radio,cigarette lighter, heated rear windows, plastic trim on the outside, larger plastic bumpers, plastic hubcaps, fog lights, vent. fan, rear seatbelts, electric windscreen washer etc) plus the BIS has two boots :)
That's all from the top of my head.
Simon
« Reply #2 on: October 25, 2009, 01:01:09 AM »
Cheers very much GT
ATB
Simon
« Reply #3 on: November 03, 2009, 09:10:14 PM »
Hello! In addition to GTMasters comments, the engine displacement was increased to 704cc and watercooled but used the same block as the previous aircooled engine. In addition, the engine has been laid flat with two cylinders side by side, providing some useful luggage space. It is also much quieter that the previous aircooled engines. The air intakes had to be made larger because of the watercooled engine, the wheels were increased in size to 13 inches to improve the ride and payload and, most importantly, at the rear there is a top hinged hatch with twin gas dampers, and a bigger rear window with optional wash/wipe. Additional kit was added such as electric wash rather than the manual one, intermmitent wipers, reverse lights, rear foglamps, rear parcel shelf, storage space and front headrests (89 year onwards). From what I have read, all Fiat 126s from 1988 onwards, Fiat used galvanised steel for the first time.
