Author Topic: engine shaking  (Read 2703 times)
prkahrvat
  • PEGLATRON
engine shaking
« on: October 23, 2009, 02:19:55 PM »
My engine is shaking like hell. Before i remove engine all work well. But after i repair engine and pun inside car after i start engine it start shaking. Its shaking so hard that whole car is shaking. Does anyone know what could be the problem? Engine holder is put good. I have removed engine several time and this is first time its shakes like this.
Sorry for bad english!
Re: engine shaking
« Reply #1 on: October 23, 2009, 04:41:46 PM »
Are both cylinders running? Is there enough oil in the engine and is the oil pressure good? The engine on mine once started shaking a lot because the second cylinder's exhaust rocker slipped off the valve. After pushing it back with a large screwdriver and checking the clearence all ran well again. Yours might have the same problem.
« Last Edit: October 23, 2009, 04:44:41 PM by GTMaster »
Re: engine shaking
« Reply #2 on: October 23, 2009, 04:46:01 PM »
As GTmaster said, check both pots are running, timing might be an issue, also check the gearbox mounts are ok.
Re: engine shaking
« Reply #3 on: October 23, 2009, 06:52:48 PM »
what repair did you do? did you remove the flywheel?
Re: engine shaking
« Reply #4 on: October 23, 2009, 08:45:20 PM »
Doesn't the flywheel have an offset bolt pattern?
Re: engine shaking
« Reply #5 on: October 23, 2009, 11:05:09 PM »
i cant say if it is as whenever i have removed the flywheel i have made marks beforehand to aid alignment however i know of cases where the flywheel has been put back wrong and thrown the engine out of balance.
prkahrvat
  • PEGLATRON
Re: engine shaking
« Reply #6 on: October 24, 2009, 12:44:47 AM »
nope, i removed head. Both cylinders are working ( whole engine runs perfectly ), didnt touch flywheel, timing is on 10°.
i have 2,5 l of oil ( like in the manual ). Didnt touch gearbox, before removing engine everything was fine ( except [i think this word is good translated] seal beneath head ). I think maybe its engine mount but i removed engine several times before and never had same problem. After i give little throttle it stop.
prkahrvat
  • PEGLATRON
Re: engine shaking
« Reply #7 on: October 24, 2009, 12:48:02 AM »
its not seal, gasket is correct word
Re: engine shaking
« Reply #8 on: October 24, 2009, 10:34:17 AM »
from what you describe here i think that you have set the idle too low and the engine turns over so slowly it throws the engine side to side. adjust the idle and see if stops the other potential area is like you said the engine mount just make sure you have put it all back in the correct order as its very easy to get one bit wrong and thats it all cocked up.
prkahrvat
  • PEGLATRON
Re: engine shaking
« Reply #9 on: October 26, 2009, 12:12:18 AM »
Is there any pictures of correct order?
I put rubber and little pipe below, upper parts first are rubber on metal holder of engine, spring, rubber, metal circle, and screw.
ill try to set idle too...
